Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 10-14-2010, 04:23 PM
DelSol911 DelSol911 is offline
Exclamation need any ideas have tried almost everything....
my del sol has been acting up latley. the battery light fades in and out and the headlights and radio cut in and out when the battery light is on. i put a new battery in, that wasnt the fix, the alternator has been tested 4 times, past all four times. im now noticing an aceleration difference while the battery light is on as well any ideas on what it could be will greatly help out
Old 02-05-2011, 12:19 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: need any ideas have tried almost everything....
it's an electrical load, no doubt. The question is whats the load? I think it might be the voltage regulator within alt as that's what causes the light to come on. I would consider an alt change even though you say it's been tested. Is your connection good at the alt? Is it good at the battery?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 02-06-2011, 10:57 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Check your belt tension, and not only that..if your belt is old, replace it. They slip, no matter how tight they are, and will continue to do so if they are hard and worn. I have had alternators test out beautifully, and fail to maintain 11v output when in the car...stumping me for days, until I realized that a pry bar to the tensioner would shoot the voltage right up.
Also I dont trust those auto part store testers anymore. After going through 3 days of second guessing myself with 3 different stores testing it out as "good" I took it to an alternator repair shop, and it put out less than 20A. 15 min, 20 bucks and a set of new brushes and my measly stock alternator pumped out 175A! I had always though that voltage would drop at idle in that car, and as it turns out it was a dying alternator for over a year. Long story short, take it to a real shop if you want a proper test. They can even do it in the car running if you can manage that.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Tried everything to eliminate exhaust drone... any ideas? pinoy_styles Integra 0 11-12-2008 03:04 AM
Help ,,, Need Any Ideas On My 93 Astro jwy M Bodies 1 12-07-2005 09:11 PM
97 blazer still not starting tried almost everything projecthellraiser Blazer 5 06-25-2005 12:14 AM
Gas in my oil.... any ideas on a fix... I have tried numerous things... no luck chatterx General Discussion 31 08-02-2004 10:24 AM
I need any ideas for turbo systems or superchargers for my rabbit cuda352 Rabbit 1 02-29-2004 09:33 PM
Tags
del , electrical , headlights , help!!!!!!!!!! , sol
