Old 06-21-2005, 12:55 PM
projecthellraiser projecthellraiser is offline
97 blazer still not starting tried almost everything
i have a 97 blazer. i was going down the road the other day and it started to miss then it stalled. i restarted it and it died again. i brought the blazer back and started going threw it the fuel pump is fine, im getting 60psi fuel presure. i just replaced the cap and rotor and it will atleast miss but it still wont run. i have to recharge my battery now. but what could it be? jumped timing, ignition module, ignition switch, or fuel pressure regulator? i also have had the coil pack tested and it was alright. thanks for your help lance
Old 06-21-2005, 12:59 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 97 blazer still not starting tried almost everything
ignition switch to me.
Sounds electrical.
Also check the coil for arcing at night.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-24-2005, 10:09 AM
Re: Re: 97 blazer still not starting tried almost everything
Sounds electrical.
Ok I replace the CAP & ROTOR and found alot of carbon buildup, and alot of arcing. i also charged up my battery overnight. when i went out to try to start it it will crank, but now it fires and misses. so started to press the gas and i got it to stumble for abouyt 30 sec then it died again. i think it might still be fuel related. its still getting 64psi at the shrader valve. could it be the F/P regulator? also how could i check it. thanks lance
Old 06-24-2005, 02:14 PM
BlazerLT's Avatar
AF -Advisor
fuel filter ever changed?
Old 06-24-2005, 11:00 PM
it hasnt been changed but would a clogged filter cause lower pressure? i will try one in the morning if that could be the cause but i dont want to just start replaceing everything till its fixed. thanks lance
Old 06-25-2005, 12:14 AM
BlazerLT's Avatar
AF -Advisor
It can cause the engine yo be starved of fuel.
You also need flow along with pressure.
