Old 10-13-2010, 10:04 PM
bugman742002 bugman742002 is offline
please help
i have a 93 mustang with the 2.3 in it. i had the compression tested the other day and was told that all 4 cyl were at 50 psi. it currently has 160,000-170,00 miles on it. it doesn't burn any oil but drinks gas like it has a big block under the hood. 8-12 in the city and 17-20 on the hwy. anyone have an idea what it could possibly be?
Old 10-14-2010, 12:21 AM
Boost1egt's Avatar
Boost1egt Boost1egt is offline
Re: please help
hi bugman. I have some questions. How often do you change the oil on the car? M/T or A/T?
Old 10-14-2010, 12:24 AM
Re: please help
i change the oil every 3,000 miles or 3 months whichever comes first. it's an automatic.
Old 10-14-2010, 12:35 AM
Boost1egt's Avatar
Re: please help
ok, thanks. Why do you say it doesn´t burn oil?
Old 10-14-2010, 12:42 AM
Re: please help
i drain the same amount of oil as i put in at every oil change. i don't have to add any to it between oil changes either.
Old 10-14-2010, 12:55 AM
Boost1egt's Avatar
Re: please help
Oh, I see. I asked this, because sometimes, when we change the oil when we should, (like you do) we don`t perceive an important consumption of oil like we would see if we drive the car 4 or 5 months without changing the oil.
Have you checked the sparkplugs to see how they´re burning? How do they look?
Old 10-14-2010, 12:59 AM
Re: please help
plugs look normal but will have to check them again tomorrow. also it is starting to run a little warmer than it usually does. it's normally near the lower part of the gauge now it comes up to the middle of the gauge when i stop at a stop light. and the radiator is still full so no coolant loss so far.
Old 10-14-2010, 01:06 AM
Boost1egt's Avatar
Re: please help
When an engine runs rich, it runs hotter. Check if the MAP sensor its out of calibration.
How does the car feel? Do you feel like it has lost a significant amount of power.
Old 10-14-2010, 01:10 AM
Re: please help
yes it has lost alot of power. what bothers me is the low compression readings. i may have to recheck that latter today or friday.
Old 10-14-2010, 01:18 AM
Boost1egt's Avatar
Re: please help
Yea, the engine´s probably tired. If you let the engine warm up for a while, and remove the oil fill cap, you can expect some gray vapor to come out when an engine´s tired.
Old 10-14-2010, 01:20 AM
Re: please help
ok will check that later this morning. so it looks like it is time for a rebuild.
Old 10-14-2010, 01:34 AM
Boost1egt's Avatar
Re: please help
Yea. Thanks for the patience, man. Hope that was helpful. Dont forget to let us know what you find if you find something.
Old 10-14-2010, 01:37 AM
Re: please help
thank you for giving me a few ideas and things to check out. i was ready to pull my hair out and torch the car. i will let you know what i come up with as the culprit.
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
Please Help!! Please Read!!! Please Help!! FromZtoSUV MX-6 0 10-10-2008 08:41 AM
Please Please Help - Fuel Pressure Regulator Jewlio Eldorado 2 07-22-2004 09:39 PM
pLEasE HELP! Engine vibrates!Appreciate any help poisonko Accord/TSX/Accord Hybrid 0 05-04-2004 12:07 PM
need help deciding......help please =D sylojai '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 01-27-2002 06:43 PM
