Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-13-2010, 01:03 AM
kenmtb kenmtb is offline
Drove car w/o oil I think
Hello-
I have a SW2 and as I got home I noticed the temp gauge was higher than normal and the fan kicked on. No warning lights came on so I was surprised to find the dipstick had no oil on it. The car ran fine, no noises just hotter than normal. It probably ran hot for a less than a minute before I reached home.
I will be checking the oil constantly from now on.
Did I do any damage to the motor?
Thanks
Old 10-13-2010, 01:54 PM
yost.josh yost.josh is offline
Re: Drove car w/o oil I think
in future you could possibly blow engine. Bearings would probubly go bad first if anything is wrong.
Old 10-13-2010, 02:28 PM
Thanks for the reply. It took 2/3 quart to get the oil to show on the dipstick. That's how low it was. I don't think it actually ran dry. The coolant was very low. The low coolant light has always flashed even when it is full.
Today the car ran fine. Temp perfect and no abnormal noises. I hope the high temp was from low coolant.
So is it possible that no damage occurred?
Old 10-15-2010, 12:05 AM
lotsoffear lotsoffear is offline
There is an oil treatment out there I swear by, espically in Saturns that are know for using oil. It is called Dura-Lube. For extra protection I would add it (around $15).
(Slick-50 and Lucas Oil work good too, I just have allways used Dura-Lube)
In my first Saturn (94 SL) I added this treatment at the recomendation of a buddy. Later, my sister borrowed the car, hit something in the road, punctured the oil pan, then drove it until it died. After I had it towed home, I figured it was a gonner. Well the next day I fixed the oil pan, added oil and it started right up. I ran it for another 120,000 miles (until I get rearended at 55mph).
I have used Dura-Lube in every vehicle I have ever had since. Including my current 97 SL2 that has almost 220,000 miles.
Old 10-15-2010, 11:09 PM
So far so good after a few days of driving. Temp is good and MPG is normal. Still no noises. I guess it will be fine.
Old 10-15-2010, 11:26 PM
danielsatur danielsatur is offline
If not touching stick, it probable was 2-quarts short.
Oil check light will trigger @ warning!
Just Tires has a $19.95 oil change special, but cost $4 to throw away the old oil filter.
Oil in my air filter and car holds no oil 92Ply-Laser Eclipse Problem Diagnosis 2 03-21-2005 07:50 PM
drove car through water Onlyeyes Regal 10 11-10-2003 07:10 AM
Littering Charges Face Man Who Drove Car Into Lake taranaki COMPLETELY off-topic 3 07-27-2003 05:19 AM
