Old 10-09-2010, 08:50 PM
gmbwrenchn gmbwrenchn is offline
Floor shifter solenoid problem
97 Blazer 2nd Generation. 116k miles 4.3LTR.
Have the floor shifter. The interlock solenoid in the shifter has been acting up. Doesn't want to release. When I press on the brake, it will flutter in and out. Is the solenoid bad or something else I should look at. Thanks for the help.
Old 10-11-2010, 10:54 PM
old_master's Avatar
Advisor/Moderator
Re: Floor shifter solenoid problem
Could be the solenoid, the switch, or a poor connection.
You have to know how it works,
to figure out why it doesn't.
Old 10-11-2010, 11:25 PM
Blue Bowtie's Avatar
Registered Offender
I've had at least two of these get gummed up and fail from someone spilling a beverage onto the shifter. When the water evaporates all that is left is the sticky, gooey syrup which freezes the solenoid very nicely. Clean water and an air hose solved that in both cases.
Old 10-17-2010, 08:48 AM
Looks like it was a combination. First, which I can't believe, was a broken, loose wire. Second I used some electrical spray to free up the gummyness. Works like a charm now. Thanks for the info.
NOT the shifter solenoid - what else could it be?? PhyllisNi Grand Prix 9 12-29-2009 10:50 AM
Want to Convert; Auto Steering Column Shifter to B&M Auto Floor Shifter thedeem0n Chevelle 1 06-04-2006 12:22 PM
1977 Dodge B100 Van Floor Shifter Jackie321 Ram Van 1 10-18-2005 09:21 AM
wobbly tilt steering column with floor shifter guahanx Sierra 3 10-20-2004 08:39 AM
column to floor shifter swap....powerglide CHINGAS Camaro Discussions 0 02-13-2004 11:50 PM
