Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-08-2010, 05:34 PM
jer2266 jer2266 is offline
95 Jeep GC overdrive problems
overdrive button not working also when i start driving from a complete stop its like its in 2nd or 3rd gear its 1995 jeep GC laredo automatic 4.0L 260,000 miles
Old 11-20-2010, 11:32 PM
mynewestautos mynewestautos is offline
Banned
Re: 95 Jeep GC overdrive problems
Check automatic transmission fluid AFT
Check the ATF only after the transmission has been warmed up to operating temperature.Park on a level spot, put on the handbrake, leave the engine running at idle, and locate the ATF dipstick. This might be located along the back of the engine, but there are other possible places, depending on the make and model of the engine and transmission. Consult the owner’s manual or an auto technician if you are not sure. Do not confuse the transmission dipstick with the oil level dipstick. The ATF dipstick usually is much shorter and has writing on it, indicating what it does.
Pull the dipstick out and wipe it with a clean paper towel. Re-insert it and check the level several times until the readings seem consistent. The fluid is moving around and has a tendency to splash a bit giving changes in readings. If the level is low, fluid is added using a small funnel down the dipstick tube itself. It’s very important to use the correct fluid for your particular vehicle and that information is likely both stamped on the dipstick itself and printed in the owner’s manual. The fluid should be a nice red or pink color, not brown or smell burnt.
Old 11-30-2010, 09:16 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
do you have a check engine light on as well? Overdrive not working could be either a bad overdrive solenoid, or the wiring is bad, a blown fuse or worse case scenario the overdrive clutch is burned up. The starting off in high gear is because the governor is sticking thus not allowing the tranny to downshift. Being that you have 260,000 miles, if you haven't already had the tranny rebuilt, you probably are due for a rebuild.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
OVERDRIVE problems jer2266 Grand Cherokee | Grand Cherokee SRT8 2 10-11-2010 09:28 PM
97 jeep cherokee A/C Problems jeepguy4life Cherokee 4 07-20-2010 12:28 PM
2004 ram 1500 4.7 overdrive and idle issues mrwrench Ram Pickup | Ram SRT10 2 06-03-2010 10:22 AM
1984 jeep problem help crasherdude3 Cherokee 6 09-01-2009 02:15 AM
Re: 94 Jeep Grand Cherokee Limited Overdrive Problems mitch2005 Grand Cherokee | Grand Cherokee SRT8 2 12-19-2004 10:46 AM
