Old 07-24-2009, 02:27 PM
crasherdude3 crasherdude3 is offline
1984 jeep problem help
alright i have a 1984 jeep wagoneer 4x4 (cherokee body style) with a carb. 2.8 when it is cold it has no problems but when it has been running for about 5 min or warm at all when you floor it it will sputter out and die. but when its cold and you floor it it raps really quick and sounds clean with no blow by at all but if when its warm i easily give it gas it will rap just fine but if i take it to like 3k then floor it it will do it if i go to any rpm and floor it it does it. i live on the high way and really sucks to take 3 miles to get up to 60mph
i have a new fuel pump fuel filter i have put carb gas treatment in twice the whole bottle each time recomended 25 gal i put it in at 15 gal it will do it with or without the air filter assy on i have been told the carb needs rebuilding the tank is not venting right the pump is bad the injectors in the carb i am stumped
could the timing be off it does sound like an exhaust leak that ticking sound but it is all sealed up nice i think it may be slight spark knock
any thoughts yes swapping a 3.4 would be cool but i dont have the feciality to do it or the money to buy the engine or else i already would have
Old 07-24-2009, 02:38 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 1984 jeep problem help
I had the exact same problem on a car that I had...we rebuilt the carburetor (incorrectly, it turns out) and it would run great until it warmed up, then have absolutely no power.
IMO a new carb will take care of it; but before you go to that expense, check all the vacuum hoses in the engine compartment, on some carbureted vehicles lack of vacuum can cause issues.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 07-24-2009, 02:48 PM
ok i have checked and all the vacuum is hooked up and there is no leakes
Old 07-26-2009, 09:32 AM
IMO after 25 years you need a new carburetor. Or it could be rebuilt.
Old 07-26-2009, 02:23 PM
rhandwor rhandwor is offline
Napa makes good rebuilding kits. Soak in cleaner or boil in an old pan for 20 minutes rolling boil with all rubber parts removed.
Follow the directions completely. Use compressed air or carburetor cleaner and clean out all orifices. Use a vacuum pump and check all vacuum pull offs.
Use a table where you can find any items you may drop. Take your time and finish the job.
Old 07-26-2009, 03:02 PM
racerxpl racerxpl is offline
It sounds like the auto choke is not opening. or has a weak spring and closes when you press the gas. I have had a couple of vehicles do this.
Old 09-01-2009, 02:15 AM
oljeeptek oljeeptek is offline
There is an adjustment for mid throttle fuel enrichment that needs to be opened slightly. I went round and round when these were newer, You'll need the double "D" shaped socket to turn it. Also make sure that if you have the electric mixture actuator at the rear of the carb that the mixture pins are moving when you look down the bowl and rev it up and down. Ifits stuck or nonfunctional mid throttle performance will suck and bog/surge.
Remember...
Old Jeeps never die, they just sometimes look that way!
Tags
2.8 , blazer , carb , jeep , s10
