Old 10-08-2010, 01:43 PM
inafogg inafogg is offline
TESTING FUEL PRESSURE 97 Lesabre
hello,& thanks for info
im working on 97 Lesabre 3800 w/80k
i suspected it had low fuel pressure in checking w/cold engine turn key
to on gauge reads 20psi i no its low should be 47-55psi
if i reprime no change.when running 25-30psi
when i left gauge on (key off) to check leak gauge reads 40-45psi after 5-10 min. fuel reg seems fine(no gas in vac hose) my question is do
i have a weak pump? other than a rough idle at start up(lack of fuel)
which clears in 30-60 sec & a P0171 P0300 lean & miss fire the cars
runs very good.its my sons car & dont want to guess.could it be some
thing else like a leaking intake or from the readings im getting do
you think its a pump for sure
Thanks again mike
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 10-08-2010, 06:44 PM
maxwedge maxwedge is offline
A990 racer
Re: TESTING FUEL PRESSURE 97 Lesabre
The pump is bad or the filter is clogged.
Old 10-08-2010, 07:48 PM
Smitty's Buick Smitty's Buick is offline
If the pressure rises over time, I'd be looking at the filter. Definitely the right place to start as it is a much cheaper and easier fix.
Smitty's Buick
Old 10-08-2010, 08:04 PM
thanks guys, i was going to put in a new filter tomarrow i'll let you no
filter was suposably new before he got it 6mths ago.but it doesnt look new
Live For Today
Yesterday is gone,
Old 10-09-2010, 01:57 PM
ok filter in, brought pressure up to 38psi(it was clogged) guess im pulling tank
thanks again
mike
Live For Today
Yesterday is gone,
Old 10-09-2010, 03:41 PM
Blue Bowtie's Avatar
Registered Offender
You can either pull the tank and clean it or keep changing filters The on danger is that the sediment in the tank can clog the pump inlet strainer (sock) or damage the pump.
Old 10-09-2010, 06:41 PM
ok if i go the ''keep changing filters'' way what can i exspect
over time i'll clean out the tank but still need the pump??
over time the cleaning will/may increase the pump pressure??
or am i just buying time & the pump will still need replacing.
after taking the old filter off & seeing its condition i feally thought
that was the problem.now i wonder what the sock looks like
no ck engine on so far but still stumbles at cold start if its not not going to get any better i'd rather replace the pump now as its still warm outside & thats where i'll be doing the work
Thanks again guys mike
Live For Today
Yesterday is gone,
Old 10-11-2010, 09:06 PM
Registered Offender
About the only way to diagnose this is by testing pump pressure and flow. Pressure should build to a minimum of 43 PSIG with no vacuum at the regulator, and the pump should be able to move a minimum of 1.5 pints (24 ounces) in 15 seconds at 43 PSIG. Less than that can indicate a restriction in either the pump or filter (or, less likely, the lines).
The pump should have a 100-120 mesh strainer (about 150 microns) on its inlet. It is a turbine type pump so a little sediment will pass through with no real damage but a lot of sediment can eventually wear the impeller and volute, causing a drop in pump performance.
Old 10-28-2010, 08:09 PM
ok was going to replace fuel pump but both carter & delphi brands
would'nt work??after replacing the f/p connector(included w/delphi)
the insulator @ bottom of pump would.nt go on enough to install strainer(sock)
ck & carter is the same.do you replace sender & all or pump only?? in
the past i've replaced the hole unit.this was the 1st time a pump was offered
by itself
thanks mike
Live For Today
Yesterday is gone,
Old 10-28-2010, 08:46 PM
Scrapper Scrapper is offline
AF Premium User
heck i'd go ahead to and put new fuel pump ,sock,screen and be done with it and if you get it at adanced or autozone there lifetime as long as you own the car. if you put new pump you wont have to drop the tank again if sock pluggs up again.
Old 10-28-2010, 09:35 PM
imidazol97 imidazol97 is offline
AF -Advisor
by itself
thanks mike
I'd agree about replacing the whole unit including the sender and the pipes. Some have had leaks in the metal pressure pipe from the tank to the rubber hose that goes on to the fuel filter due to corrosion. I had that on my 98 due to salt or the brine solution they put on the streets and roads here in W. Ohio.
I also know the mechanic I had do it would not put on any brand other than the Delco brand which I assume is what you're getting as Delphi. He said they had too many failures with other brands for GMs where they have to replace them at their cost within a year or whatever was the warranty period for his work. I do know they had trouble getting the right gasket for the flange on top of the tank and had to reorder through the local GM dealer to get the right one for my 98 leSabre.
Old 10-28-2010, 10:19 PM
thanks for info
waiting on parts house never had a problem but
may need a dealer part
thanks again
Live For Today
Yesterday is gone,
Old 10-29-2010, 12:25 PM
ok no luck w/parts house.contacted dealer they do not sell the unit
as a complete assembly.you buy the pump or sender separately
im having them pick one up dont no if it will be the same as
the delphi ? cant believe no one else has run into this
i'll post back
Live For Today
Yesterday is gone,
Old 10-29-2010, 01:09 PM
AF Premium User
i'll post back
did you try carquest or nappa?
Old 10-29-2010, 05:57 PM
ok got it figured out dealer pump was the same as delphi
the difference was the strainer (delco)it has a longer connector
on it about 1/2 vs 1/4 to install it on pump
pumps in, pressure back 50-52
need to no where i can get new quick disconnect seals
can'nt find without buying the fuel flex line(dealer)
thanks again ev 1
mike
Live For Today
Yesterday is gone,
Testing fuel pressure regulator jeffk388 Grand AM 5 10-23-2007 05:29 PM
Testing fuel pressure 2001 v6 ekul43230 Malibu 1 09-09-2007 09:44 AM
testing fuel pressure regulator and crankshaft position sensor sylbry Aurora 1 01-02-2007 04:47 PM
How-to test fuel pressure on my 90 CRX Si? YZ125rider21 '88 - '91 Civic | CRX | Wagon | Shuttlee 9 01-12-2006 08:39 PM
Testing fuel pressure php Rodeo | Passport | MU 2 10-29-2005 09:51 AM
