Old 10-06-2010, 01:49 PM
pitbullvassar pitbullvassar is offline
98 Ford, only goes into 4 wheel sometimes
Hey, just picked up a 98 ford f 150 4 X 4. We drove it and couldn't tell if the 4 X 4 was working. Put it up on jack stands, and when you switch it over, sometimes it works, others you can hear it laboring, but not engaging. Not quite a grind but close. And ideas?
Thanks
Neil
Old 10-06-2010, 10:46 PM
jyount jyount is offline
Re: 98 Ford, only goes into 4 wheel sometimes
I think the front axle itself has an electric disconnect. If it is not working, the transfer case output can't power the front wheels because the differential won't let it....
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 10-06-2010, 10:49 PM
One up that one...
It is also vacuum activated, not electronic, so the accuator itself may not be bad, check for vacuum leaks.
Current job: RN
Wife's
Old 10-14-2010, 05:42 PM
big white bufflo big white bufflo is offline
there is a vacume servo on the right hand side of the diff make sure that is lubed they hang up it gets it vac from a swtch on the fire wall
81 Chevy only goes in 4 wheel low bighutch30 C/K 1 06-03-2006 10:21 AM
power window only goes down ab6cr Rodeo | Passport | MU 4 03-21-2006 08:13 PM
93 towncar brake pedal goes to floor--sometimes 1977 Greyghost Town Car 3 12-23-2005 09:11 PM
It only goes in reverse..... Omni Freak Lemon Law 1 12-30-2004 09:26 AM
89 civic won't shift past 3rd tach only goes to 3500 rpms. miata_chick_01 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 07-19-2004 05:58 PM
