Old 10-06-2010, 09:05 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
1.9L Timing Belt Specs (1993)
My '93 1.9L had a loose timing belt so I tightened it up. It now makes a 'whirring' sound and I think it may be too tight. My 'incredible' Haynes manual has a diagram of it that says "check tension here" but it doesn't say how much play it should have. Does anyone know how much play there should be on the long stretch between the camshaft and flywheel? By the way it is running perfect at 316,000 miles
Nevada Tumbleweed
Old 10-06-2010, 12:16 PM
Davescort97 Davescort97 is offline
Escort guy
Re: 1.9L Timing Belt Specs (1993)
I don't have a book that tells the deflection. Last time I put on a timing belt I just left the timing cover off so I was able to measure the amount of travel at the center point of the belt between the cam sprocket and crank sprocket. Mine measures 1/2 inch and that's the amount of tension using the spring loaded tensioner pulley. My belt is probably stretched out a little bit so maybe 3/8 to 7/16 of an inch would be better. 316k on your Scort. Wow, that's a lot of miles. You must be doing something right.
Old 10-07-2010, 07:40 AM
Thanks, Dave.
Nevada Tumbleweed
Old 10-07-2010, 03:53 PM
rhandwor rhandwor is offline
My old manual said to take belt in your fingers and twist 90 degrees. If you can go past this its to loose if you can''t make 90 degrees its to tight. Once you get one correct its easy but depends on how strong you are and how hard you twist. I would say moderate pressure. This is in the long stretch.
Otherwise buy a belt tension gauge. http://www.uktools.com/
Search timing belt tension gauge. Facom makes them.
87 Escort 1.9L timing belt issue Keg914 Escort 8 12-20-2010 08:02 PM
2000 Mirage 1.8 Timing Belt changeout Mangoacn Mirage 0 12-18-2009 08:51 PM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
95 Escort LX 1.9L Timing Belt, what else should I replace at same time? dlbdata Escort 9 12-18-2004 09:57 PM
96 escort 1.9L timing belt replacement easypace Escort 4 11-05-2003 04:16 PM
