Old 10-05-2010, 08:47 PM
Keg914 Keg914 is offline
87 Escort 1.9L timing belt issue
I have an 87 Ford Escort GL with the 1.9L engine in it. My father in law had it sitting in a field for about 3 years without it running. Needless to say, it's kinda rusty. But it's still in pretty good shape for just sitting there for 3 years. Anyway, the timing belt must have broke on it and I would like to put a new one on. I have removed the timing belt cover, and aligned the camshaft and the crankshaft. But, I can't get the crankshaft pulley off to get to the crankshaft sprocket. It looks pretty rusted on there. Is there any way to get this off? I have tried lubricant to see if it will loosen up the bolt any, but so far have had no luck. If I can’t get the crankshaft pulley off, is there any other way to get the timing belt on? I even tried to use a screwdriver to pry the flywheel where the starter connects so that the crankshaft won’t move when I try to take that bolt off. But no luck with that either. Any ideas?
Old 10-06-2010, 01:12 AM
Davescort97 Davescort97 is offline
Escort guy
Talking Re: 87 Escort 1.9L timing belt issue
I think I have just the ticket for you, but first you'll have to put the starter back in. Once you've done that put a breaker bar with a socket on the crank pulley bolt. Lower the car until the breaker bar will hit the ground on the right hand side when the crank pulley is turned. While holding the breaker bar and socket in place have an assistant hit the starter. He may have to hit the starter more than once, but that stuck bolt will be history. I've always used an impact gun, but this way will work just as well.
Old 10-06-2010, 07:28 PM
Cool. Thanks. I'll try that. Also, would you happen to know if this engine is interference or non-interference?
Old 10-06-2010, 08:51 PM
old_master's Avatar
Advisor/Moderator
non-interference
You have to know how it works,
to figure out why it doesn't.
Old 10-07-2010, 08:53 PM
Hey, another quick question. How bad is it to have a little screw driver, no more than 2 in long, in the flywheel housing? I tried to get it out of there, but I could not find it. Everything still spins fine right now, but I don't want that screw driver getting caught in the flywheel.
Old 10-09-2010, 03:57 PM
rhandwor rhandwor is offline
Remove the access plate you use to unbolt the torque converter. Use a small magnet on an extension the transmission should be non magnetic so you can try to fish it out.
Old 10-17-2010, 05:56 PM
Another question. Where is the fuel pump relay located on this car?
Old 12-15-2010, 02:34 PM
FordMan59 FordMan59 is offline
Fuel pump relay is located on the ECU bracket under the drivers side dash back near the firewall. There are two relays, a green/black and a brown/black. If memory serves me correct the green/black one is the fuel pump relay.
Old 12-20-2010, 08:02 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
You will need a pulley puller to get that crank pulley off. The right tool will make quick work of it.
95 Escort LX 1.9L Timing Belt, what else should I replace at same time? dlbdata Escort 9 12-18-2004 09:57 PM
'93 1.9L Escort snapped timing belt, what else to check? Thirdgen89GTA Escort 11 12-09-2004 10:33 PM
1998 escort 2.0 timing belt interval bbjjkkdd Escort 3 09-01-2004 05:00 PM
95 Escort engine noise...timing belt?? Bric Escort 3 08-05-2004 05:46 AM
96 escort 1.9L timing belt replacement easypace Escort 4 11-05-2003 04:16 PM
