Old 10-06-2010, 05:37 AM
libertyspike138 libertyspike138 is offline
Biggest tires for 94 Caravan
Hello I have a 94 Caravan and 94 Grand Voyager. Neither of these vehicles have a hitch standard but I had them installed at uHaul. The hitch rides so low that it hits and scrapes the ground sometimes on inclines and such. My question is what are the biggest tires that I can safely install to get a little more clearance from the ground without the tires rubbing? The vehicle standard is 205 70 15 & 15 x 6 aluminum rims.
Old 10-11-2010, 02:50 PM
Re: Biggest tires for 94 Caravan
Anyone?
Old 10-11-2010, 03:57 PM
b1lk1 b1lk1 is offline
Is the rear sagging? I have a hitch on my 02 and even with the stock 16" tires (which are not much larger in circumference than your 15") I don't have clearance issues. Sounds like you need air/helper shocks.
Old 10-11-2010, 04:07 PM
Yes even when the van is empty and not hauling anything the bottom of the hitch scrapes on the ground when entering driveways and alleyways etc..
So is it the last number in a tire size that determines the height? You have 16 inch, are these on the 15 inch rims? Do you still have a bit of clearance for even larger tires?
Old 10-15-2010, 06:18 PM
I have just under 9" of ground clearance to the lowest part of my hitch assembly. Even when my trailer is attached (and that drops me down to about 5-6" of clearance) I only scrape on sharp steep angles. Overall tire size is a function of the entire formula. I believe that the 215/75 R15 tires have the same overall diameter as the 225/60 R16.
Old 10-17-2010, 11:04 PM
moparman58 moparman58 is offline
Here's a handy tire size calculator that you can compare tire sizes with.
http://www.1010tires.com/TireSizeCal...?action=submit
Diameter is the height of the wheel rim the tire goes on. So, no, a 16 inch tire won't fit on a 15 inch rim.
Some other issues you might want to look at are new rear shocks, maybe something like Monroe's Sensatrac Load Adjusting Twin-tube Shock Absorbers. I intend to put a set of those on my T&C.
Another option would be putting on Timbren rear suspension enhancement kits:
http://www.etrailer.com/susp-1994_Ch...nd+Country.htm
Kumho tires for Caravan farmer11 Caravan | Voyager 4 10-11-2007 12:16 PM
biggest tires for chevy truck? jveik General Discussion 1 11-20-2006 05:25 PM
Biggest Tires for Stock Suburban K2500? ToddnMiss Suburban 2 03-14-2006 12:17 AM
Biggest tire For 02 LS TurboB LS | MKZ 1 02-27-2006 08:33 AM
biggest tire for the wheel paulmeister Tires and Wheels 1 01-16-2006 06:02 AM
Tags
1994 , big , caravan , hitch , tires
