Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 10-05-2010, 08:52 AM
michtui michtui is offline
Battery Loosing Connection
I have an experience with my Toyota Corolla while driving at 60Kph and the power shuts down and the engine stop, then I look inside the hood and check the battery and hit the pole connector and fortunately my car got it power back, what do you think about this experience, any suggestion which one do I need to replace battery or the battery clamp?
[ad link removed by moderator]
Old 10-05-2010, 10:45 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Battery Loosing Connection
First off welcome to AF!
Sounds to me like it is a corroded battery cable or loose ground. Check the cables at the post connections for any swelling or stiffness...corrosion of the copper inside can build up and make it hard to flex. If good, take a solution of dissolved baking soda and pour it over the battery terminals to dissolve and neutralize any corrosion or buildup. Rinse off with a slow stream of water...do this outside and away from others. Then remove the cable connections and clean the battery's terminals with a wire brush. Finally, follow the black negative cable to a ground connnection on the car body and make sure it isn't rusted or loose. Clean with wire brush and retighten. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
98 528i replaced battery, but connection is loose jeffbeck 5 Series 1 11-23-2005 07:23 PM
possible loose connection? perna00 Grand AM 1 06-14-2004 05:39 PM
possible loose connection? perna00 Cavalier 2 06-10-2004 05:02 PM
electrical glue? loose connection to speaker. whiteracer Car Audio 2 08-29-2003 08:36 PM
Electrical issues, bad ground? loose connection? Motro Mofo Engineering/ Technical 2 08-22-2003 12:17 PM
