Alternator problems?
Just drove 700 miles (11 hours ) the last 100 in the dark with lights on and wipers going. All of the sudden the wipers would only work in one speed -- which was slow. Next the battery light flashed on and of f every five minutes, then ABS and airbag lights came on. Turned off an exit and headlights began to dim, battery light stayed on and car died. Is it pretty safe to say a bad alternator? Until this happened no difficulty starting or any sign of bad alternator or battery. Can an alternator go that quickly?
Re: Alternator problems?
Well it sure sounds like it went bad, but you can't say it was quick. You may have developed a problem just before your trip, say a bad cell in the battery. Driving 11 hours with large load on the alternator would fry it for sure.
That's just an example. There is no way to tell what went wrong until you pull the alternator and have it tested. In my experience, batteries and alternators go bad in pairs if both are old. If the alternator was good, then a bad battery left go too long kills the alternator and vise-versa. Be sure to test both. |
Turns out battery was OK and alternator was bad. Replaced alternator and is running fine now.
venturenot, how hard was it to replace the alternator? I just recently purchased my 98 venture and last night I had the same problem headlights dim, batt light on and loss of power.
Alt can be a pain. I have done one with the intake on and one with off. I dont really recall how I did the one with the intake on, but I know with it off it was pretty tight.
1997 Chevrolet Venture SFI 3.4l Auto 249k 2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k http://www.s10forum.com/forum/attach...nsor-chart.gif |
Don't know, my mechanic in PA did the work. It cost me $320.00 which included Alt, New belt and labor.
Replaced mine on saturday wasn't to bad just had to drop the subframe to get the motor low enough to get it out.
There ya go, knew there was an easier way to do it!!!!!
![]() And if you forgot to disconnect the steering linkage, I wouldn't want to pass you on the road--the linkage could snap at any time after that stress. You have got to be kidding! Folks, the alternator comes right out if you just remove the top motor mounts and loosen the bottom one at the oil pan. Roll the engine forward with a ratchet strap and there is enough room in back to fit a cooler past the engine. Really, it takes like 15 minutes to get the alternator out. |
Its seems odd for me to be posting NOT to remove the subframe, I like to do that for almost any engine work that takes more than a little effort--see my post (with many pix) on how to do just that here: http://www.automotiveforums.com/vbul....php?t=1049830
But the truth is, that's NOT a trivial job while changing the alternator is trivial. |
