Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-02-2010, 11:57 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Possible vacuum leak?
When i did my engine swap i tested for this already and didnt find anything... When i do a cold start the RPMs seem normal but sort of flutter. Once the RPMs slow down the engine will start to struggle and itll stall if i don't feather the throttle, which means the choke gets kicked off and then i really have to baby it until its fully warmed up.
At first i thought it might be the fact that i don't have the stock air cleaner on (with the exhaust heat thing). But it still does this when the temp is around 70, so it must be a vacuum leak right?
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 10-03-2010, 08:43 AM
Blue Bowtie's Avatar
Registered Offender
Re: Possible vacuum leak?
It's not necessarily a vacuum leak. It COULD be a vacuum leak, either external from a hose, brake booster, or gasket, or an internal leak from a gasket, EGR valve, or EVAP purge.
But it could also be a MCC adjustment, fuel bowl level adjustment, clogged jetting, saturated float, incorrect TPS setting, and various other causes.
It's fairly easy to check for vacuum leaks, so that would be a good starting point to eliminate that possibility.
Old 10-03-2010, 08:51 AM
j cAT j cAT is offline
could be vacuum leak. what is the vacuum at the intake port with the engine at hot idle 650 rpm in neutral? should be 17-20 inches.
If low good chance PCV worn or hoses to from this.
the next area would be the carb pull off diaphrams leaking .
the hoses can be checked with a T connector vacuum guage and pinch lines to see if vacuum is being lost on that line/device.
the original air cleaner needs to be installed now...
Still check for proper vacuum at every oil change .
Old 10-03-2010, 10:24 AM
bhw33191's Avatar
Thanks everyone i'll use your advice when i go home next week..hopefully i get this thing in tip top shape before the winter here in maine!
Possible Vacuum Leak Bodack Eclipse Problem Diagnosis 1 08-23-2005 10:29 PM
Any tips on finding a possible vacuum leak? diy-dad M Bodies 2 02-14-2005 08:22 PM
99 'Burb- possible vacuum leak cjevans C/K 1 06-18-2004 12:24 PM
High Revving /possible vacuum leaks Carb88AccordLX Accord/TSX/Accord Hybrid 0 06-19-2002 10:36 PM
