Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 10-02-2010, 11:32 AM
rolla1 rolla1 is offline
headlight issue
hey i have 2003 sunfire i am currently having trouble with one of the headlights, i replaced the bulb and checked all the fuses and still no luck. just wondering what else i could check.
Old 10-02-2010, 11:48 AM
danielsatur danielsatur is offline
Re: headlight issue
Test and make sure you are using a known good bulb & fuse.
Old 10-02-2010, 12:03 PM
Re: headlight issue
The fuse and bulb is good. Still nothing????
Old 10-03-2010, 12:16 PM
Re: headlight issue
i ended up checking the wiring and notice alot of the wires where in bad shape . replaced most of the wiring and the lights are shining bright now. Thanks guys
Old 10-03-2010, 07:37 PM
Re: headlight issue
i just noticed that after fixing the headlights that the highbeam do not function. i tested the bulbs and they are good. was just wondering what i should check next....
Old 10-03-2010, 07:42 PM
Re: headlight issue
Do the bulbs have two filaments?
One for the low beam, the other for High beam?
Old 10-03-2010, 11:15 PM
Re: headlight issue
The bulbs i have only have one filament in them...
Old 10-04-2010, 11:58 AM
Re: headlight issue
The resistance of corrosion can cause the bulb to not work, clean sockets, and use a bulb grease for protection.
Old 10-04-2010, 04:52 PM
Re: headlight issue
whats a good cleaner to use so that i don't damage the socket?
Old 10-04-2010, 07:08 PM
Re: headlight issue
CRC Electrical cleaner.
Make sure, your car doesn't require a two filament bulb!
95 Firebird TA Headlight issue... vegaslt1 Camaro Discussions 4 12-09-2005 05:47 PM
92 Corolla DX Headlight Issues chrisg000 Corolla/Matrix/Voltz 2 12-28-2004 09:57 PM
97 blazer headlight issue tspencer73 Blazer 3 10-06-2004 02:14 AM
Major Major Headlight Issues. Your A Geneious If U Know... Djs87 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 16 06-14-2004 09:40 PM
93 Ford Escort Headlight issues! HPDOFNTX Escort 3 05-19-2004 02:11 PM
