Old 10-01-2010, 11:03 AM
mtech mtech is offline
97 Taurus 3.0L U No Start
I have the above mentioned car that wont start,no ecm communication,Relay Control Module clicking rapidly.Car will fire right up with starting fluid.got a used RCM,no change.I have searched engine compartment and checked/cleaned all visible ground locations,fuses all appear good.Both cooling fans run @ key on.Car was driven to its current location,car sat for a week,battery died and was replaced with new and this problem started,short of buying subscription to Info database, I have not found any wiring diagrams,HAVE searched forum and not found answers.
Thanks for your time
Old 10-01-2010, 08:41 PM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: 97 Taurus 3.0L U No Start
Sounds like you might have a ground problem at the Constant Control Relay Module (CCRM). I'm not sure how to explain the lack of communication with the ECM though. Do you know that the scan tool used to work with this car? Have you checked the battery voltage when trying to start the car to make sure you got a good battery?
-Rod
96 windstar 3.0L tramission problem Steve45ca Windstar 3 01-17-2010 04:56 PM
92 taurus 3.0l engine wont start Skip202003 Taurus | Taurus Wagon 10 05-29-2007 09:25 PM
96 Taurus 3.0L, Power steering/Radio Problem masdawg1981 Taurus | Taurus Wagon 1 02-23-2005 08:04 AM
idle surging 91 taurus 3.0l GreyHawk Engineering/ Technical 1 05-07-2004 09:26 PM
'99 Taurus 3.0L Vulcan Idle Surge bc.mht Taurus | Taurus Wagon 1 08-29-2003 04:17 PM
