Old 09-30-2010, 05:20 PM
vibeguy vibeguy is offline
2006 Grand Prix clunking in front end
my 2006 grand prix has multiple clunking when starting or stopping coming from the front end, both sides on occasions it seems. 2 shops couldn't find the source. GM dealer wants to start ripping apart the engine. Any ideas? Was thinking of replacing lower control arm bushings. Thanks for any info!
Old 10-01-2010, 10:40 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2006 Grand Prix clunking in front end
Welcome to AF.
What's the mileage on your GP?
Timeslip 08/12/06
AF Community Guidelines
Old 10-01-2010, 03:24 PM
It has about 40,000 mi. Thanks for responding.
Old 10-01-2010, 03:28 PM
BNaylor's Avatar
Thats low mileage to get noises from either the suspension system or drivetrain or engine for that matter. Can you better describe the sounds you are getting or conditions? Was this purchased new or used?
Timeslip 08/12/06
Old 10-01-2010, 04:39 PM
It was purchased used with 14,000 miles. Maybe a rental? Was originally titled in CA. Anyway, at first it was the occasional single clunk when starting out. It's progressively gotten worse with multiple clunks nearly everytime accelerating and stopping. Doesn't really seem to be steering related, just starting and stopping. Time line from first heard till now is under a year but more than a couple months.
Old 10-01-2010, 04:41 PM
3100 3100 is offline
Banned
sounds like the dog bone, or to use professional term "torque strut/mount"
Old 10-05-2010, 12:43 PM
rkvons's Avatar
rkvons rkvons is offline
Couldn't it also be a broken front stabilizer link?
Old 10-06-2010, 09:25 PM
Thanks for the info guys. It's the wife's car and she's getting antsy and has her mind made up on bringing it in. I'm going to tell them to change the lower control arm bushings and check into the sway bar links. Seems common problem on GM's? I checked the dogbones and they seem alright. Held the brake and hit the gas. No noises, seem to be ok. I'll post an update after.
Old 10-07-2010, 12:32 AM
Banned
There is only one dog bone, don't confuse it with engine mounts on top. This one is on the bottom and on front passenger side. Control arm bushings you can check when front side is lifted in the air. The rubber part of the bushings should be in place. If the rubber part is hanging then it is bad.
Old 10-07-2010, 11:27 AM
BNaylor's Avatar
It depends on the engine on how many dog bone engine mounts. The L32 (Supercharged) and L26 (NA) SIII 3800 engines have two. GXP with with LS4 5.3L V8 has one on left, top, front side of engine only.
To the OP what engine or model Grand Prix do you have?
Nonetheless, too bad the OP only has the 3 yr/36,000 mile GM factory warranty since this is a 2006. For 2007 and up it is 5 yrs/100,000 miles. An issue like the OP has could be covered sparing expense.
Timeslip 08/12/06
Old 10-12-2010, 04:06 PM
Took the car to the dealer as stated. They found it. Couldn't believe what it was. The brace above the Battery on the P.S. that goes on an angle was loose. Must have not been retightened enough after the battery was replaced last winter. They tightened it down, no more clunk. Second time I brought it in, figured it out after an hour this time. Didn't charge me anything. Can't complaign about that. Thanks for all the info though. Appreciate it.
2002 pontiac grand prix gtp front end clunk thecrow1986 Grand Prix 25 05-05-2010 09:29 AM
Clunk in Front End 97 Blazer Massguy Problem Diagnosis 3 07-05-2009 08:02 AM
1997 Grand Prix SE front end bumper Centrinomw Grand Prix 19 08-15-2007 06:38 AM
1999 Grand Prix GT front end noise pezfooty Grand Prix 12 04-03-2007 03:43 PM
99 Grand Prix GT front end noise turning to right with engine running firefiretiger Grand Prix 2 09-23-2004 10:01 PM
