Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-29-2010, 05:35 PM
VinceH VinceH is offline
2000 Rodeo Spark Plugs
All,
So I just got my Denso plugs delivered and before I begin the task of changing them out, I have a couple of questions even though I have read many of the post related to this one the site:
1, Does the coil and the tub come out as one piece?
2, If they do not can the tub be put back into place on the coil pack and reinstalled or is it best to purchase a new coil pack?
Thanks
Old 09-29-2010, 06:27 PM
danielsatur danielsatur is offline
Re: 2000 Rodeo Spark Plugs
1) Disconnect the signal wire going to the COP.
2) Take the screw out holding the COP.
3) Pull the COP straight up.
4) Visual inspect plug + COP for water or oil contamination, this could cause a misfire.
Only replace COP's as needed.
Old 09-29-2010, 06:45 PM
Thanks for the reply but that didn't answer either of my questions...
Does anyone know :
Thanks
Old 09-30-2010, 09:52 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Does anyone know :
Thanks
it is a 2 piece unit but they typically come out as one.
You can use the coil pack until you get a check engine light that will let you know which coil is bad. If the coil pack pops off you can just push it back on and if it doesn't stay, when you screw it bad down it will be fine.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 09-30-2010, 10:23 AM
Perfect, thank you.
Old 09-30-2010, 03:40 PM
Usually how long do the coil packs last? I have almost 150k miles on them now. Interesting that the CEL will tell you which one goes bad.
Old 09-30-2010, 05:36 PM
Isuzu Guy
In the ten years I've been reading Isuzu sites I can only remember a couple of posts about bad coils (but that didn't stop me from buying 3 used ones 5 yrs ago).
I would bet you can easily get 250k out of them.
-Ryan
Isuzu Moderator
Car Show Tips
Old 10-01-2010, 04:03 AM
Cat Fuzz Cat Fuzz is offline
Coils are pretty reliable and rarely fail. Pretty much sealed copper wire windings surrounding an iron core. Not much can happen to make them go bad unless there is a break in the insulation and something inside corrodes.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
98 rodeo spark plug gap sathead3 Rodeo | Passport | MU 5 05-05-2008 09:25 PM
2000 Rodeo Spark plug wires HOW! troy1126 Rodeo | Passport | MU 2 02-09-2005 10:05 AM
