Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 09-29-2010, 04:26 PM
vanhaaren vanhaaren is offline
Humidity while running the heater
2002 Montana. Regardless of the temperature or season, when I run the heat, the cabin is instantly humid and the windows are fogged up within a minute. The floors are dry. The heater core is DRY.
Here's the strange part; with the temperature set high I can stop the humidity by hitting the AC switch on. It will then blow warm DRY air.
Old 09-29-2010, 05:38 PM
mastertech1964 mastertech1964 is offline
Re: Humidity while running the heater
there has to be water getting into the car somewhere somehow, turning on the a/c does dry out the air in the interior thats why most cars automatically switch on the a/c compressor in defrost mode to help with defogging the windows
Old 10-01-2010, 09:08 AM
o.k., let's say I have a very slow leak in the heater core (slow as in maybe it's just releasing some steam). Would it make sense then that the a/c control turned on would remove that 'steam'.
The thing I don't like about that theory is that when the heater is on and the air is humid, I don't smell antifreeze and there is no greasy film on the windows.
Old 10-01-2010, 04:54 PM
3100 3100 is offline
Banned
Is your antifreeze level decreasing slowly? This still sounds like a heater core.
Old 10-04-2010, 06:39 PM
yeah, a slooooww leak is present. But I can't smell anti-freeze in the 'humid' air. My mechanic's been at the heater core twice and it's been DRY. That's why I'm thinking that maybe it's just a steaming leak once it's hot and under pressure.
The A/C switch still confuses me though. The A/C can't really be running when I have the temp set to HOT and it's cold out....can it?
I pulled the ECM B out while running/ now it won't start. KMatsko M Bodies 1 04-10-2010 08:42 PM
Fan always runs when the engine is running boomboom SC/SL/SW 8 09-16-2009 01:06 PM
Does running the heater decrease gas mileage? Ducaire S-10 29 12-23-2005 08:20 AM
98 Blazer 4WD Engages while stopped but not while on the fly chigger23 Blazer 8 08-07-2005 11:39 PM
tahoe tries to stall while running rdp C/K 4 02-03-2004 01:48 PM
