Old 04-07-2010, 07:42 PM
KMatsko KMatsko is offline
I pulled the ECM B out while running/ now it won't start.
I was going to add a pound of R-134A and chill out a bit. I noticed that the A/C clutch was not turning, so while the vehicle was running and the pound can of refrigerant was still hooked up to the low side service port, I took out the wrong fuse. My 1999 Chevy Astro van's 4.3 stalled. Now it won't start.
The factory security system was partially removed when I bought it, the PCM won't give me any codes, but the MIL ligt comes on when attempting to start it. Fuel pump primes. I got the van last year Feb. 09 and never had a problem.
Please help.
Thank you all for the consideration. I will make a profile and get to know people.
Old 04-10-2010, 08:42 PM
Blue Bowtie's Avatar
Registered Offender
Re: I pulled the ECM B out while running/ now it won't start.
If you replaced the fuse with the ignition on make sure it is still intact.
Try disconnecting the battery overnight. I had a '96 that got erroneous data after charging with a booster and was able to clear it by a disconnect overnight.
Tags
iko
