Go Back   Automotive Forums Car Chat > Ford > Excursion
Old 09-29-2010, 03:05 PM
familyfarm familyfarm is offline
Question 2000 Excursion Cruise Control
Any help on this one? My 2000 Excursion has been doing fine. I occasionally use the cruise control, but when I went to set it the past few trys, It would not work. All fuses are good. When I push the cruise it will not go on, there is no light indicating its on, and nothing happens when I try and set it. Any answer will be appreciated. Thanks
Old 09-29-2010, 05:26 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2000 Excursion Cruise Control
Is the brake light switch adjusted properly? Sometimes the switch will drop and allow trhe cruise to think the brake is on and not allow the cruise to engage. Try using your toe to pull up on the pedal to see if the cruise will engage.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-30-2010, 09:54 AM
I gave that a try!! When I set the cruise button, the dash indicator light does not even come on. I was reading more and see that there is a recall for possible fire hazard from the cruise control. There was something about the pressure switch leaking brake fluid onto the wireing harness. looking cat the Master Cylinder I do see a switch on the end of it and it is wet with brake fluid. I am not sure if this is the point of the issue. I am trying to contact Ford Motors to find out.
Old 09-30-2010, 06:04 PM
way2old's Avatar
TOKEN HILLBILLY
If you want to send me the VIN, I can run it to see if there is a recall on it. Or just call a local dealer and ask them about a recall on the cruise control. It is a free fix also.
2000 ford excursion Price... The_last_regulator Excursion 2 09-22-2010 09:52 AM
Cruise control freak out cobraprince 3000GT/Stealth 13 03-23-2009 10:41 AM
1998 Zx2 Cruise Control Problems ddppci ZX2 1 02-17-2009 10:59 AM
2000 elantra cruise control tyler77 Elantra | Avante 1 06-12-2004 12:44 AM
2000 Cherokee Cruise Control On/Off Button jpg2esq Cherokee 1 02-06-2004 05:00 AM
