Go Back   Automotive Forums Car Chat > Ford > Excursion
Old 09-21-2010, 08:20 PM
The_last_regulator The_last_regulator is offline
YES CHEVY IS LIKE A ROCK!
Question 2000 ford excursion Price...
Hey everyone.
Hope yall are all doing good.
Ok heres whats up...
I was told this truck had been setting for about a year.
My friend has a 2000 ford excursion black 4 door 5.4 Triton.
Verry verry big and nice...
It needs work and it has some dents and dings....No wrose then what i have now -2000 ford explore sport 4.0- with dents and dings
My question is what are things i should look for??
I know to check the tires for lineament problems.
The engine seems good NO SMOKE BUT HAS 211k on it!!!!????
also when you 1st start it you can here what sound like valve clattering BUT THE SOUND IS COMING FROM SOME WARE UNDER THE ENGINE -im thinking a rod or oil pump-
The best way i know to describe the sound is valve clatter or pully or bearing sound.
The truck holds good oil pressure. gauge was in the middle between high and low
The sound goes away after running for about a min.
The sound does not get worse when reving.
If i put it in D and hold the brake and push the gas the sound does not change.
I did not get alote of time to check the truck out but i will tomorrow.
I would like some ideas on what this sound could be .
What price range I should be thinking about .
and what are the cons or major problems with these trucks?
O it said it had been getting 7.1 mpg avg UMMM wtf???
Thanks for yalls time. GOD BLESS and support our troops...THANKS
Old 09-22-2010, 09:24 AM
Franco2112 Franco2112 is offline
Re: 2000 ford excursion Price...
Sounds as if it needs a good oil change. It could be low, dirty and also have a lot of water and or condensation in it. Not good for lubricating. As for the mpg 7.1, that is consistent with Excursions. More than likely why your friend parked it. I would offer him no more than $2000 for it.
Franco
Old 09-22-2010, 09:52 AM
youngkia1's Avatar
youngkia1 youngkia1 is offline
Authorized Kia Vendor
Franco
I am agree with you, just to add up consult the an expert with regards to this to avoid any inconvinience in the future.
Northern Utah Car Sales
2000 ford explore Misfire with NO CHECK LIGHT? The_last_regulator Explorer | Explorer Sport Trac 15 09-14-2010 11:50 PM
2000 Ford Windstar, Not a whole lot of knowledge cshawn Windstar 8 08-14-2010 05:40 PM
2000 ford v10 excursion idle problem buster177 Excursion 2 10-26-2005 07:44 PM
2000 Ford Excursion Limo 4limo Excursion 0 03-16-2005 11:32 PM
Tags
2000 , excursion , ford , price...
