Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-27-2010, 02:46 PM
MNJet MNJet is offline
99 Suburban Positive cable bolt
Hi guys,
This is an awesome forum. It has helped me alot in trouble shooting my veichles. This is my first post, so bear with me.
I have a 99' Suburban and I need to change the positive cable bolt. I notice that the threaded portion of the bolt looks like a cap that is crimped to the main bolt. How do I remove this lower threaded section to replace the whole cable bolt?
Thank you in advance,
MNJet
Old 10-08-2010, 06:28 PM
j cAT j cAT is offline
Re: 99 Suburban Positive cable bolt
Originally Posted by MNJet View Post
Hi guys,
MNJet
this bolt in the battery cable is steel. the battery threads are soft lead. how is it that the steel stud is in need of replacement ?
never had to remove these studs from the cable ends.
I have to assume they will unscrew with some extra pull when rotating.
use the vice grip pliers.
'94 JGC Laredo Crankshaft Position Sensor Bolt Size pete44 Grand Cherokee | Grand Cherokee SRT8 4 01-31-2008 06:29 PM
88 GMC Suburban Speedometer Cable littlefoot84 General Discussion 1 06-28-2007 01:15 AM
90 Suburban Positive Battery Cable and Vacuum Lines romancatholicism Suburban 5 05-25-2006 03:27 PM
Positive cable grnding to engine Chambers777 S-10 5 01-07-2005 10:37 AM
positive cable help! chevelle2fast4u Chevelle 2 01-01-2005 08:49 AM
