Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-24-2008, 06:18 PM
pete44 pete44 is offline
'94 JGC Laredo Crankshaft Position Sensor Bolt Size
Hello...I am having the honor of TRYING to change out my CPS in my '94 JGC Laredo with 4.0 Litre engine. .I have a couple of feet of socket extensions BUT I cannot get the bolt loose...Is it a 7/16 " ? ..I tried various sizes...I saw that size memtioned in another post...ALSO, I have a 4 WD....That makes it harder to get at bolt since axle/differential in way.I am thinking of getting it on jackstands. .Does anyone have the best procedure for this?...Again, it is a '94 JGC Laredo with Auto-4WD and 4.0 Litre engine...Thanks,Pete
Old 01-25-2008, 07:15 AM
Re: '94 JGC Laredo Crankshaft Position Sensor Bolt Size
So, I should go out and buy a KIA? ...You may have something there ....Anyone been through this?.....Or, at least the bolt size?.... ......Thanks again, Pete
Old 01-25-2008, 11:12 AM
JeepForever JeepForever is offline
Another post said it's 11mm. See my more detailed answer at:
http://www.automotiveforums.com/vbul...d.php?t=882494
Old 01-26-2008, 07:28 PM
CoachKarl CoachKarl is offline
I just pulled my CPS off of a 93 - 4L Grand Cherokee. 2-11mm bolts.
Old 01-31-2008, 06:29 PM
95zj-tilshedies 95zj-tilshedies is offline
Pete, I just changed out my CPS (on a '95 4.0L). It was a 7/16" bolt, and it took me about 18-20" of wobbler extentions and a swivel at the socket heat to get it off. I don't know if the '94 is the same as the '95, but mine had only one bolt holding the sensor in place.
