Old 09-23-2010, 01:06 AM
Firebird1 Firebird1 is offline
Send a message via AIM to Firebird1
Reverse Lights
Hello could anyone out there know why the reverse lights goes out? Help please. Thanks.
Old 09-23-2010, 12:00 PM
91STT 91STT is offline
3SNJ Pres
Re: Reverse Lights
Your question is a little vague but some reasons any light may go out are bulb, switch, open circuit, corrosion, or damaged socket.
1991 Stealth R/T TT
It looks stock, so it must be.
Old 09-23-2010, 06:15 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Reverse Lights
Are the reverse lights stuck on or do they not work?
If they're stuck on then I would say it's most likely the sensor. If they don't work at all it could be a number of things. Fuse, sensor, wiring, or bulbs.
Old 09-23-2010, 08:54 PM
Re: Reverse Lights
Sorry about my question. When I put the car in reverse the lights doesn't work. I have change the bulbs and I get nothing. I took my antenna out to repair it. Dose the antenna has something to do with not having reverse lights? A sensor where is that located? Maybe I can probe it to see if its getting any power.
Old 09-24-2010, 05:24 PM
3SNJ Pres
Re: Reverse Lights
check fuse #18 under the dash first, it is a 10A fuse.
if it is good, check the back up light switch on the transaxle.
it is towards the front of the car on the right side of the car.
it is a 2 wire switch and the colors are red/blue (to lights) and black/white (to fuse #18).
if you short the 2 pins together with the key in the on position (engine need not be running), the light should turn on.
if the back up lights turn on replace the switch.
if not than you have to find an open somewhere.
1991 Stealth R/T TT
Old 09-27-2010, 05:15 PM
toddrs93's Avatar
toddrs93 toddrs93 is offline
Re: Reverse Lights
did you get this fixed? If not we are not too far away, we could check it out for you.
Old 09-28-2010, 12:15 AM
Re: Reverse Lights
Thank you 91SST I will try this and let you know. Also thank you toddrs93 for the offer. Let me see if I can locate the problem first. If not then I may consider bring the car to your shop, Thanks again.
Old 10-20-2010, 06:13 PM
Re: Reverse Lights
Hi, no did not get it fixed. I looked where the shift cables goes to a linkage, but did not see the wires that were mention. Does the switch stick out from the transmission case on the front?
rear-light warning signal and reverse lights up on brake 1993 Camry LE V6 patmanj20 Camry/Camry Hybrid/Vista 7 07-24-2008 02:01 AM
Reverse lights,alarm lights &signal indicator doesn't work Bigpauly52 7 Series 1 06-08-2005 03:34 AM
'90 Chevy 2500. No reverse lights. Where is Backup light switch? kpwall Engineering/ Technical 0 01-11-2005 08:46 PM
2000 Silverado--Reverse lights/cargo light Ruralmedic Silverado 6 12-30-2004 08:20 PM
no backup lights - reverse light switch? blhfla Golf 2 02-08-2004 02:51 PM
