Old 09-22-2010, 07:58 PM
razorb razorb is offline
Talking 99 starting hard
My 99 3500 5.7 L cranks for a long time before it starts Runs fine after it starts Sometimes it starts just as i'm letting go of the key buddy says maybe pick up coil? any help appreciated
Old 09-22-2010, 08:59 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 99 starting hard
Check the fuel pressure. Make sure it pumps up to at least 60psi key on engine off, and then make sure it doesn't drop off immediatly.
To me it sounds like your fuel pressure regulator is the culprit for the long start times. You may be able to peer into the throttle body, or just remove it, and look at the top of the LIM for a washed spot where its clean from a gas leak at the FPR. Look in the t-body towards the even bank of cylinders. If there is a clean spot, gas is leaking in.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
2002 Suburban - Motor Swap - Won't Start mrharris32 Suburban 5 09-22-2010 06:48 PM
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 02:01 PM
hard to start when cold 88alldae Caprice 2 08-03-2009 09:16 PM
2000 3.0 24v hard to start wagon. Tglass Taurus | Taurus Wagon 4 07-07-2009 02:26 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
