Old 09-21-2010, 04:49 PM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Cool Convert Gen-3 Firebird To Independent Rear End
1982-2002.
Can it be done? My friend wants to keep his rear planted - if you know what I mean! He wants the FRONT of the car to get to his destination first, even if he is leadfooted.
Old 09-22-2010, 10:17 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Convert Gen-3 Firebird To Independent Rear End
Stick with the solid rear. Independent rear is better for handling, solid rear tends to be better at launching. Plus, the unibody/subframe construction of those F-bodies is not designed for a stressed third member. You would be placing a ton of torsional load on the rear chassis of a car that is designed to simply suspend weight.
Dragging people kicking and screaming into the enlightenment.
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
Rear end noise fastlane85023 Mustang Problem Diagnosis 4 11-29-2009 07:39 PM
1987 Dodge Dakota 3.9L V6 Rear end tag number HELP! knjwells Dakota 2 08-30-2009 04:39 PM
3/4 ton rear end noise Repo_agent C/K 4 11-15-2005 08:44 AM
95 1500 4.3 1/2ton rear end problems steve k felton C/K 3 10-27-2003 03:42 PM
Tags
firebird , suspension
