Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 05-19-2003, 02:55 PM
neunan neunan is offline
Send a message via AIM to neunan
Question applications of different suspension set ups
aright, so i'm finally getting a new suspension this summer. i searched the forums yesterday for every topic dealing with coilover sleeves vs coilovers vs springs...and its pretty crazy out there! a friend of mine told me that coilovers are more adjustable overall BUT you have to adjust them prior to each surface that you're going to be driving/racing on - making them perfect for actual racing, GT, whatever. he also said that with a good set of springs/shocks (by shocks i mean like...koni yellows. misconceptions throw everything off) you'll get better average performance in any area. my goal is GT style mods. with this car i would never spend the amount to make a true GT car, but thats the direction i'm going. so...lots of hard turns, random drag-like straightaways, and eventually i want to eliminate most of the understeer. and this car is a daily driver, so i have to consider the harshness of the ride around town (eliminating true coilovers from what i hear?).
so i guess my question is, what are the application differences between springs/dampers, coilover sleeves, and coilovers? after reading everything i still havent gotten a clear answer to that. thanks
96 Accord EX 5spd coupe - black
AEM cai * DC Sports cc 4-2-1 header * GReddy EVO catback* AEM trupower pullies * ACT HDSS clutch kit * ClutchMasters 8lb flywheel * NGK blue wires * 4 wheel Brembo slotted rotors with AEM pads * 4bidden Motorsports shortshifter
pioneer deh9300 * phoenix gold zero point wiring * blaupunkt pa2100 pushing diamond audio HEX 6.5 comps in front * blaupunkt pa275 pushing power acoustik fahrenheit 6x9s in back* 5" LCD TV * 8-bit original NES
Old 05-19-2003, 04:52 PM
90EX 90EX is offline
I have Tein SS coilovers (on my 90 Civic) and they ride great. But it depends on how it is adjusted. If you have the car slammed all the way down, the ride will be harsh.
The adjustable shock setting also makes a big difference. For my daily driving, I have it set on soft and it feels like my old stock shocks.
Old 05-20-2003, 02:13 AM
BullShifter's Avatar
coil-overs are coil springs on struts with a threaded collar to adjust the amount of stiffness & lowering. A good set of coil-overs starts $800. If you do not plan on using to the full potential they are over kill & you feel it in the ride. Dont try to save money here
Damper, Shocks, Struts are all basically the same thing. With out these your springs would continue bouncing after a bump. Also the shocks are what mantain contact to the road surface not the spings
for street use a good set of spings & shocks should be fine.
Add or increase the size of the rear sway bar to reduce under-steer then you induce over-steer(snap-steer)
Different camaro set ups z28 boy Camaro Discussions 1 06-09-2004 09:18 PM
suspension set ups Lastkiss8988 Tires and Wheels 1 10-01-2003 11:28 PM
Can I see some of your speaker set-ups? regg Car Audio 24 08-04-2003 12:59 AM
Custom Nitrous Set Ups kicker1_solo Car Modeling 0 08-18-2002 10:09 PM
Best Shocks and Coilover set-ups?? SiRWannabe '88 - '91 Civic | CRX | Wagon | Shuttlee 4 06-07-2002 03:02 AM
