Old 05-18-2003, 07:03 AM
BOOSTD's Avatar
BOOSTD BOOSTD is offline
How do you lower your Fujimi models?
I am starting my 180SX soon and I want to know the best way to lower it. I am pissed off that Fujimi didnt give me the option to lower it like they do with the Integra. I really want to slam it because it will be a drifter. Is there anywhere I can read a step by step guide?
Old 05-18-2003, 08:54 AM
phase5's Avatar
phase5 phase5 is offline
The best way to lower it is to place on the floor and JUMP ON IT .
no im trying to lower my veilside s14 and still have not come up with a plan yet
glue glue and more glue
www.djamos69.com
Old 05-18-2003, 09:15 AM
Towelboy80's Avatar
Towelboy80 Towelboy80 is offline
Here is how I lower my cars:
I'm not a drawer .
Fab
___
In progress:
CivIntegra
Civic Ferio... Veilside version
Old 05-18-2003, 10:36 AM
theoldboy theoldboy is offline
bit kike tamiya kits really hard to lower,no room inside the wheel arches you could try cutting the top off the wheel and glue it to the wheel arch
maybe someone out there knows ,i dont
Old 05-18-2003, 10:40 AM
bigfrit's Avatar
bigfrit bigfrit is offline
Towelboy is absolutely right;
I used a similar technique, lowering teh sprins and reshaping (sectioning and re-gluing) the triangles.
This should be an easy way, as long as you cut them at equal lengths.
This was used on my ITR and I was really satisfied with results.
Oh, and I don't reccomend Theoldboy's method, because you will lose the realism of the suspentions.
Olivier
Old 05-18-2003, 10:42 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Just cut and remove whatever interferes with the tire.
Hiroaki Fukuda
Old 05-18-2003, 10:50 AM
Towelboy80's Avatar
Olivier
It's called the belgian technique.
( joke )
Fab
___
In progress:
CivIntegra
Old 05-18-2003, 10:56 AM
joecwlaw's Avatar
joecwlaw joecwlaw is offline
guys, try to see my old thread on how to lower a S14 (Early Version)......hope it can help you in some way
Old 05-18-2003, 12:08 PM
Suislide's Avatar
Suislide Suislide is offline
you're building the exact same 180SX as i am. what are your plans for it for color and wheels etc.? i'm making mine a drifter as well. it definitley needs to be lowered, as i've seen a couple of built ones on AF that weren't and they look like 4x4's. i'll probably be using the technique of cutting part of the shock off.
-Brian
2013 Subaru BRZ Sport-Tech 6MT. Not stock.
Old 05-18-2003, 01:13 PM
modelcarmaster16's Avatar
modelcarmaster16 modelcarmaster16 is offline
HAHHAHAHA
Old 05-18-2003, 04:30 PM
Neige Neige is offline
i've built one of these b4, not lowered....but i swapped 18s on it and i dont even hav enuff space to lower it anymore, so check wut type of rims ur gonna put on b4 lowering
Current Projects:
[img]http://us.st2.yimg.com/store6.yimg.com/I/matrixcollectibles_1732_31118213
[/img]
Old 05-18-2003, 08:05 PM
joecwlaw's Avatar
sorry I forgot to put the link of the old thread:
http://www.automotiveforums.com/vbulletin/t74204.html
quoting the details from my old thread:
guys, I am working on initial D s14 early version. the kit is good, it comes with extra parts, Nismo Skyline GTR racing seats, exhaust(larger), and flat wing.
However, I have to lower the car since its ride height is very HIGH. I chopped the front suspension and A-arm for 3.5mm, and the rear for 1.5mm. It is totally pain in the ass, I spent over 10 hours doing the mod job. And for the rims, I am thinking to put vienna crisis for it, still not decided yet. your input is welcome.
As I said, the suspension was moved towards the inner, you can see the inner hole and the original hole was filled with putty. and in the second pics, the A Arms were moved upwards, so that the car is lowered.
:toothless
Old 05-18-2003, 09:26 PM
( joke )
i was joking
Old 05-19-2003, 03:34 AM
BOOSTD's Avatar
I will most likely put 17 inch Advan RG rims on the car. I am not sure what colour to paint it yet but probably a light metallic blue with gold rims or even pearl white with white rims. We'll soon see
Old 05-27-2003, 10:23 AM
BOOSTD's Avatar
Will it work if I just file all the parts on the chassis that joins the suspension and axels onto the car so that the whole suspension/axel assembly sits lower?
Where or how do you store your finished models Khier Car Modeling 10 11-26-2010 05:54 AM
how do you lower your Hydrocarbons mountie1982 Problem Diagnosis 1 10-25-2006 12:35 PM
Should you lower your ride before installing a Body Kit Wister06 Exterior | bodykits | Lighting 8 02-12-2005 01:26 AM
Have you lowered your CRX??? Marc-OS '71-'87 Civic | CRX 9 01-10-2002 02:46 PM
How do you lower the Fujimi Type-R? JDMTUNING Car Modeling 5 11-14-2001 12:35 AM
