Old 11-11-2001, 08:37 AM
JDMTUNING JDMTUNING is offline
Send a message via ICQ to JDMTUNING
How do you lower the Fujimi Type-R?
How is it done? I dont know whether you snip the suspension or have to do something else. Also I'm doing a custom interior a la the Lotus Elsise (Red Reccaros, everything else painted gunmetal to represent aluminum) as mine is a race-prepped version.
AF Tofu Crew #10
Ryosuke Takashi
It's really 350 WHP
FC3S: Wop-wop-wop-wop
Old 11-11-2001, 12:05 PM
Guiddy's Avatar
Guiddy Guiddy is offline
Scan a pick of the suspension and I can tell you, or ask pkw1!
Old 11-11-2001, 12:47 PM
primera man's Avatar
"P-Man"
Some times you can cut shocks and springs and get away with it if you only want 1-2mm.
The Subaru i'm doing at the moment i had to cut most of the suspension out of the car as it was all molded into one. Lots of mucking around but worth it.
For other cars i'f done like classic's etc i sometimes drill the chassis out so the shocks or suspension can sit further up inside.
View All My Models Here.
Old 11-12-2001, 04:24 AM
pkw1's Avatar
pkw1 pkw1 is offline
ok, you're lucky I just happened to be making 2 Integra Type-R kits right now
1st of all, you want to shorten the struts/springs by cutting out the area shown in "red" and glue the now in 2 pieces struts/springs component back together so you have a shorter strut/spring.. you do that for all 4 corners..
now that you have shorter strut/springs, your control arms will no longer fit on them right, you'll have a gap.. so what you want to do is lower the rear suspension linkages also by cutting out the areas again shown in "red" as show in these 2 photos
make sure everything is cut to the same length, so you don't have unequal lowering of the car on all 4 corners, make sure everything fit together right and straight before glueing them together
as for the front, the linkages are harder to cut due to their shape and stuff, so I took the approach of cutting the bottom of the car .. "red" areas are to be cut away,
hope this helps..
All projects stalled...
Need to settle in on my new job, and don't have time to built models just yet.
Old 11-13-2001, 03:20 PM
Thanks
It hepls but I'm going to have a 2nd rate model, as i messed up the lowering process. My models are not as good as anyones(I'm not even painting the body!!!!!!) here so when I psot my pics, pelase be merciful when judgeing them.
AF Tofu Crew #10
Ryosuke Takashi
It's really 350 WHP
Old 11-14-2001, 12:35 AM
pkw1's Avatar
Re: Thanks
hey, don't worry man you'll get good later.. we all made messed up models once too
