Old 03-08-2007, 06:37 PM
austin881 austin881 is offline
Unhappy reverse lights dont come on. bulbs are fine
Hello,
I've searched all over the internet and cant find a solution to this problem. I have a 2000 Chevy S10 pickup manual 5-speed trans, extended cab, 4 cyl engine and I cannot get the reverse lights to come on no matter what I do. I've tried brand new bulbs that I know for a fact are working bulbs because I've tried them in another S10 Pickup same year. I've also checked all the fuses and they are all fine.
Is there anything else I could check or replace to get the reverse lights working?
Old 03-08-2007, 09:25 PM
old_master's Avatar
Advisor/Moderator
Re: reverse lights dont come on. bulbs are fine
Check the back up light switch on the transmission.
http://www.partsamerica.com/productd...pe=401&PTSet=A
Should be battery voltage to one of the two wires with the key in the RUN position. The other wire goes to the lights.
