Old 05-14-2003, 09:55 PM
Tanked Tanked is offline
What's the difference between these engines?
I just got my car back from the mechanic today and he tells me that the engine in my '89 CRX Si is not the original Si engine. Under the hood, the engine looks like a D16A6. He said it probably was from a '92 Civic and he said it was a 1.6 Liter.
My question is this - Visually, what is the difference between the D15, D16A6, ZC SOHC, and ZC VTEC? The valve cover simply says "16 Valve - Honda Motor Co.".
Are there any other engines that might fit this description?
Thanx guys
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 05-14-2003, 10:00 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
look on the block for the engine code its on the left side on a flat spot, easy to see
2002 Acura TL Type S
1991 Honda Crx Si
Old 05-14-2003, 10:03 PM
chopstick1981 chopstick1981 is offline
i got the sohc zc motor and the only difference i have ever noticed is the "ZC" stamped in the block engine number. you can find the engine number below the head, just above where the tranny meets the block. Im thinkin you could probably identify it with the number. And im not sure, but i dont think honda ever made a zc vtec.
Old 05-15-2003, 07:20 AM
Whoops, I meant the 92-95 SOHC VTEC, not the ZC VTEC.
Ok, i'll try that. Thanks.
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 05-15-2003, 09:08 AM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
look at the code stamp...
d16a6: 88-91 si motor
d16z6: 92-95 ex/si motor
and the zc will have that stamped
Julian
Old 05-15-2003, 12:59 PM
Is the code stamp located above the transmission?
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 05-15-2003, 01:26 PM
ok look at the upper radiator hose follow it to where it gets to the head and go straight down, look for a flat spot its about 1 1/2" by 1 1/2"?
1991 Honda Crx Si
Old 05-15-2003, 07:24 PM
look where the red is.. you will see the motor stamp
Julian
Old 05-15-2003, 09:27 PM
Thanks guys. I found it.
And damn it all to hell, the guy I bought this car from screwed me over. He put a D15B2 in here...
With MPFI, about how many horsepower is the D15?
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 05-17-2003, 06:23 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
with the mpfi you should be around 100-105 at the crank, without its like 92
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-17-2003, 10:55 PM
Woohoo! At least I broke 100...
Could be worse, I suppose...Thanks a bunch.
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 05-17-2003, 11:02 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
damn id be pissed if I bought an si and it had a d15b2 in it ... oh well its still pretty tight.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 05-17-2003, 11:30 PM
2000dollarZCbs 2000dollarZCbs is offline
Send a message via AIM to 2000dollarZCbs
wait did you say it was vtec? cause if its vtec its better then the original SI motor.
*TeamchokE* i love to support my boys, www.HBultimatetraining.com ,
www.chrisbrennan.com ,
www.zentraediracing.com . all my boys.
Old 05-17-2003, 11:33 PM
Melt's Avatar
d15b2 doesnt equal vtec
AF Bay Area Crew
Old 05-17-2003, 11:37 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
JDM/Aussie Twin-Carb D15B 16 valves put out 103bhp, so you should be in that territory I'm guessing
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
What's the difference between these Enzos saromaki Car Modeling 5 07-29-2004 06:19 AM
what's the difference between these two kits? Orion37170 Car Modeling 14 01-12-2004 12:13 PM
What's the difference between the 4cyl engines in the Accord? rraven Engineering/ Technical 4 03-19-2003 09:59 PM
