Old 05-13-2003, 04:37 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Suspension Help Fast!!!
Here are some pics of the trouble I am having. I don't know what it is called but, it came loose while I was driving today. I know it is a little nasty down there. I just had both axles replaced recently. It looks like 2 bolts held it in place. What should I do? By the way this is the Prelude, if it mattered.
Will the bolts out of my civic fit into this. I won't be putting the civic on the road for another month or so anyways?
Old 05-13-2003, 04:38 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
looks like the sway bar to me, im not sure if the civic bolts will fit in there either.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-13-2003, 04:57 PM
T-Mo's Avatar
bump, bump, bump
Old 05-13-2003, 05:04 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
looks like the sway bar to me too
Old 05-13-2003, 05:11 PM
T-Mo's Avatar
If it is they sway bar, does anyone know the size of the bolt? I need the bolts because one is missing and the other is stripped.
Old 05-14-2003, 12:23 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Hey, T-Mo!
It doesn't matter what you call that bar, you still need those bolts. The head of the bolt is 17mm. Get yourself to a junkyard. These bolts are the same on every Honda I know of from 88 to 90-something. Find a junker, bring your 17mm socket, ratchet, and extension (and maybe a 17mm wrench) and pull 'em yourself off of just about any Civic, Accord, whatever. (Hey! Get an extra, just in case you strip the threads..)
I lost one of those when I was replacing my clutch, and I got the replacement at a salvage yard for fifty cents.
The tricky part is putting them back in. You have get both of them stuck in the holes before you try to pull the bar down to the place where they bolt up. If you don't stick them both in the holes before you tighten the first one up, the axle is in the way and you can't get the second one in the hole.
Now here's my secret trick. The part of the bar with the holes is flat. To get that bar down just where it needs to be, you have to flex it, twist it just a little bit before it's lined up where you can get the first couple of threads started. I put a big crescent wrench ON THE FLAT PART OF THE BAR, and I use that as my lever to twist.
I can put 'em in by myself, but if you've got a helper to do the twisting while the other person tries to get the bolt started, it's lots easier.
I use a 17MM deep socket with an extension on it to tighten up one of those bolts. There's a tricky way to line it up which you'll just have to figure out, but you can use your ratchet on one of them.
The second bolt, the one under the axle, can only be reached by a 17mm wrench. Use lots and lots of patience, and you can get it tightened up in about 15 minutes.
So, get your bolts, and you can have 'em back in in 15 minutes if you do it right.
Flunky
PS-Wow. It took like 500 words to explain something I could have shown you in 5 seconds.
Old 05-14-2003, 12:30 PM
T-Mo's Avatar
Thanks alot. I fixed it yesterday. Instead of pulling the bar down, I jacked up the wheel hub. It worked out perfectly. I took a screw off of a Accord. No more wobbling wheel for me. It did take all of 2 minutes to fix. I just couldn't explain to my B/F what was wrong cause I did not know what it was called. He has his own shop and was trying to help me over the phone. I did not want to get it towed to him. Thanks though.
P.S. I still don't know what it is called.
Old 05-14-2003, 12:37 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
when we replaced the axle on my freinds accord that part was the hardest to get it to line up ... eventually we did though and it was fine.
First we tried a breaker bar
so then we used the jack and improvised
And yes, that is someones residentail house with a lift in the garage.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 05-14-2003, 12:39 PM
AF Premium User
Way to go, T-Mo!
Wow! The jacking UP instead of pulling DOWN will be my next trick!
Thanks!
Flunky
PS-You said this was on a Prelude? It looked like you had lots more room to work in than I have on my civic. I'll bet you didn't have that problem of having to get both bolts in the hole. I got my first one in and tightened before I discovered the second one wouldn't go. I hate having to backtrack...
help won't start!!!! need help fast!!! bigtruckman32 Ram Pickup | Ram SRT10 0 12-16-2006 06:29 PM
Help Fast Crank Pully Removal!!! Please Help 5gcivic Neon | Plymouth Neon 6 04-01-2005 04:16 PM
I need help real bad. PLEASE help fast. [SS]Disabled Mustang Talk 20 10-03-2003 06:28 AM
Help ! My clutch? help fast plz.... DjiNN_Inc Engineering/ Technical 3 09-28-2003 03:40 AM
Big Problem Need Help FAST HELP!!!!!! 91Intergra Integra 2 09-04-2003 12:23 AM
