Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 11-03-2001, 01:02 PM
eky eky is offline
very basic question
I just purchased a 2001 g20 a few months ago, but i've only been driving it recently. what kind of gasoline do you use? i've been using just regular unleaded, but would it be better to use midgrade? i've heard that using midgrade for some cars (i.e. suvs) actually decreases your gas mileage.
thanks
emily
Old 11-03-2001, 01:18 PM
nismo_gt's Avatar
nismo_gt nismo_gt is offline
You will notice a benefit in performance & drivability with the higher the octane fuel & slightly better economy per mile (but the fuel is normally more expensive in the first place)
Primera GT
Old 11-03-2001, 05:28 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Unless you have advanced your timing, I would run 87 octane. Use the money saved towards mods.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 11-03-2001, 08:57 PM
kenchan's Avatar
kenchan kenchan is offline
i use between 87 and 89 at major brand stations only. works okay so far.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 11-04-2001, 03:06 AM
Brian P's Avatar
Brian P Brian P is offline
Send a message via ICQ to Brian P Send a message via AIM to Brian P
actually, you wont notice ANY increase in performance OR gas milage by using a higher gas grade in the G20 (unless you are advancing your timing for performance, which would require better fuel).
higher octane gasoline is more resistant to combustion. since combustion is a slow process (it takes up to 60 times longer than an explosion), it's quite possible that you wont end up burning every drop of fuel if you put premium into an engine that is tuned for 87. that may be what you heard about decreased performance with higher octanes. then again, it would probably be so subtle you wouldnt notice.
i havent confirmed that you can lose performance by using a higher than necessary grade of gasoline, but i have confirmed that it does not... COULD NOT... help either gas milage or performance. keep in mind that all the additives they put in premium, they put in plus and regular, too.
even if you dont agree with the above statement, you would have to be a FOOL to believe that putting premium gas will improve the gas milage of your car to the point where it offsets the extra cost.
i'd say that's just my $0.02... but it isnt - those are facts.
Old 11-04-2001, 07:45 AM
P10DET's Avatar
P10DET P10DET is offline
Actually, it's more resistant to auto-ignition.
Got everything else exactly right.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 11-04-2001, 12:16 PM
nismo_gt's Avatar
I stand corrected,but here in the UK there is a noticable difference
between standard unleaded fuel & Super unleaded.
I believe that Subaru even recommend the higher octane here for that very reason,my brother has a Prodrive Imprezza & the dyno showed
approx 5-7 bhp increase with the super unleaded !
So I guess its a case of try it & see
Primera GT
Old 11-04-2001, 03:00 PM
P10DET's Avatar
Yes, that is because the Imprezza is tuned for the higher octane. When you run the lower grade petrol, the knock the ECU reads the engine knock and retards the timing, keeping the engine from blowing up and also reducing the power.
If someone builds and tunes an SR20 for higher octane petrol, such as running a JWT ECU, you can run lower octane, but the ECU will pull out timing from the ignition map and you will make less power.
It's not the petrol that is making the power, but the tuning to take advantage of the higher octane.
George Roffe
Houston, Texas USA
00 328i
very basic question about speakers scoopy03 Alero 0 05-01-2007 10:27 PM
Instrument Panel lights, very basic, NEED HELP Zooropa1310 Celica 0 03-18-2007 11:29 PM
Some very basic WIP sketches evopanop Sketching and Drawing 4 11-29-2004 08:38 PM
Couple basic questions. Radocs '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 02-14-2002 08:40 PM
