Old 05-12-2003, 12:17 AM
Aiwen Aiwen is offline
Question 91 Si Alternator Removal
Hello,
I've got the bolts and belt off the alternator off my '91 CRX Si. I just can't get the damn thing out from the top or the bottom. How the heck to you remove it? Thanks
Old 05-12-2003, 01:56 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
well, i have a 90 EX and i had to pull mine from the driver's side. Pull of your wheel, and remove the splash guard and you should be able to pull it out from the side.
Empty Pockets Racing Member #1
Old 05-12-2003, 02:54 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Well the easiest way is to remove the the drivers side axel. Then it should drop right down
Old 05-12-2003, 03:51 AM
aces1980 aces1980 is offline
Re: 91 Si Alternator Removal
Originally posted by Aiwen
Hello,
Ok i just did this without removing the drivers axle, Pull it from the passenger side, go under the intake manifold and up thru the water pump. Have some antifreze ready cause u have to remove the water pump hose then keep on turning the alternator so that it can come off. It's like a puzzle. so take your time and it will come right out and just remember the position that u took it out in so that way u can put the new one in. Let me know if u keep on having any problems.
Old 05-12-2003, 01:49 PM
GScivic7's Avatar
i didn't have to do any of that...just remove the splash guard, remove the alt mount and pull it out.......
Old 05-12-2003, 04:22 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Don't take the axle out. I got mine out without having to do that.
Flunky
PS-I did have to do some wrestlin', though.
Old 05-12-2003, 04:33 PM
mellowboy's Avatar
Flunky
Yeh i didnt have to take mine out also. I was a pain in the ass so when i did my friends hatchie. all i did was take the driver axle out and the alt. came out so easy. Its not hard guys come on.
Old 05-12-2003, 05:21 PM
AF Premium User
I might try the axle method if I ever have to do it again. At the time, I was at my grandma's house and I had very few tools, so doing the axle thing wasn't an option.
Flunky
PS-When I say 'few' I mean I had a 12 MM and a pair of pliers...
Old 05-12-2003, 08:57 PM
GScivic7's Avatar
it was easier just pulling it for me than removing the axle, cause i did that the first time too cause i was replacing it anyways. is it really that freaking tight in the hatches compared to the 4 doors?
Old 05-12-2003, 09:50 PM
91bluedx 91bluedx is offline
Wait I have a 91 hatch and I have found a really easy way to get this out. All you have to do is disconnect the alternator drop it down onto the engine bay and slide on the bottom of the engine bay from the drivers side to the passengers side. It then just slimply slipping it out from around the hoses and then you got it.
Alternator removal issues calgary_89pgtt Probe 1 11-05-2004 11:16 PM
97 Grand Caravan Alternator removal todd_johnson9 Caravan | Voyager 5 10-30-2004 01:03 PM
1994 Alternator removal rlwillis Cherokee 1 01-29-2004 08:17 PM
alternator removal... jam4484 '88 - '91 Civic | CRX | Wagon | Shuttlee 15 10-29-2003 11:35 AM
Alternator removal Cervantes Cherokee 0 04-22-2003 09:20 AM
