Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-02-2001, 05:36 PM
mchomicz mchomicz is offline
Maxima rear brakes
I'm working on my rear brakes for first time and can't seem to figure out how to push the piston back in. They are discs but not anti-lock. Could it be the emergency brakes holding it ? I'm not familiar with how this system works. Any responses wopuld be greatly appreciated.
Old 11-02-2001, 09:55 PM
riceburner riceburner is offline
I assume you already have the pads off and the brakes apart.
You have to screw the piston back into the brake cylinder. The easiest way is to go to your local Autozone or whatever and purchase a brake adapter. (Looks like a cube with different pin configuration) attach this to your rachet and screw it clockwise back into the cylinder. Do go too fast or you might rip the rubber boot. Once you have moved it all the way in, you can back it out a little to get the rubber boot to unbind. :smoker2:
If you have no way to get this part (your car is without brakes at the moment) You could use some needle nose plyers but this is more time consuming.
PS don't forget to release the parking brake. This will make the job possible.
Old 11-02-2001, 11:41 PM
Thanks
OK.....I noticed the pistons had 4 grooves in it. I'm going to PEP boys first thing in the morning. Yes, it will be a long walk!
Thansk a bunch!
Mark
Old 11-06-2001, 12:54 PM
MaxRX7's Avatar
MaxRX7 MaxRX7 is offline
right on !
get the tool, needle nose pliers suck hardcore !!
Maxima parts for sale:
http://home.comcast.net/~luisrx7/MaximaParts.htm
2001 Maxima rear brake rotor removal snowking67 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 11-22-2008 04:30 PM
2000 maxima rear brake calipers LT1MAN Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 05-08-2005 08:28 PM
99 Maxima Rear Brake Piston depfrz Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 01-03-2004 11:12 AM
'99 Maxima rear brake problem buubird Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 12-03-2003 07:56 AM
1997 Maxima Rear brake groan skoobahead Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 07-01-2002 09:31 AM
