Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 05-01-2005, 04:18 PM
LT1MAN LT1MAN is offline
Banned
2000 maxima rear brake calipers
Hi, I have a 2000 maxima, and I was trying to change the rear brake pads. The first one (driver side) had no problem at all. everything went fine. but the second one, I could not get the cylinder to open wide enough, for the life of me, to get the caliper over the new brake pads. I ended up bleeding out a lot of fluid, but this did not work. It just would not budge. like there is something stopping the cylinder from going in far enough. has anyone had this happen? is this a broken caliper, or am i doing something wrong. I am using a big C-Clamp to close the calipers.
Thanks,
jeff
Old 05-02-2005, 01:06 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 2000 maxima rear brake calipers
Originally Posted by LT1MAN
.... I am using a big C-Clamp to close the calipers.
Thanks,
jeff
Rotate the piston to get the auto-adj screw (inside) to retract...
...manual surely would not hurt:
www.autozone.com ; free login
or http://www.cardomain.com/memberpage/748507/1 (bottom of page)
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 05-08-2005, 04:18 PM
rather_b_boatin rather_b_boatin is offline
You need the "box" tool. Looks like a small box with 2 nipples on each side, opposite corners. Should fit a 1/2" drive and screw in. Should be able to get at napa or a.z. (careful, this is a knucklebreaker) Look at the piston and you'll see how the tool attaches. Lube real good, my driver side would stick.
Old 05-08-2005, 08:28 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
i used a pair of needle nosed pliers to do mine.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
