Old 05-09-2003, 02:59 PM
2000dollarZCbs 2000dollarZCbs is offline
Send a message via AIM to 2000dollarZCbs
two questions....
one, does anyone know the injector order of a ZC? the spark plug wires? and second, does anyone have a picture of the bottom of their hood?, it says in most manuals that if your car is stock it will have a hose layout for the engine. i need both bad.
*TeamchokE* i love to support my boys, www.HBultimatetraining.com ,
www.chrisbrennan.com ,
www.zentraediracing.com . all my boys.
Old 05-09-2003, 04:14 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Try this firing order.
Looking at the picture, you have four snouts coming off of your distributor. If you pretend you are looking at a clock, they are at 3:00, 6:00, 9:00, and 12:00.
There's a spark plug just a couple of inches away from the distributor. Let's call that number one, just for a starting point, and the plug farthest away will be number four.
3:00=1
6:00=3
9:00=4
12:00=2
If that's not it, then start at 12:00
12:00=1
3:00=3
6:00=4
9:00=2
That's the firing order-1,3,4,2. The snout that goes to your number one cylinder should be the one your distributor rotor is pointing at when the car is at top dead center (TDC).
I looked at my Acura, to see how it was hooked up. Good luck.
Flunky
PS-The firing order in your picture is definitely incorrect. Maybe you can look at some pictures of other engine bays to figure out the hose layout.
two questions fiercecivic '88 - '91 Civic | CRX | Wagon | Shuttlee 19 05-22-2003 02:42 PM
Two questions about engine noise Fewman '88 - '91 Civic | CRX | Wagon | Shuttlee 2 01-25-2003 02:53 PM
two questions... lilypunx Cosmetics 1 07-27-2002 11:13 PM
two questions.... balishan Cosmetics 10 02-14-2002 10:16 PM
Got my Kaminari cf hood...have two questions delsolguy Exterior | bodykits | Lighting 1 12-11-2001 02:47 PM
