Old 05-05-2003, 11:33 PM
91bluedx 91bluedx is offline
Reverse light switch on Transmission
The very first post I ever made was on this topic. My reverse lights weren't workin and the people on this forum helped out alot. I looked to see if a fuse was blown but it wasn't. I pulled the enitre rear pannel apart to get a good look at the lights and there was no power going to them when I was in Reverse and then I gave up. Fianlly I got fed up and tested everything over again ( giving up is for whimps). In the daylight I realized that there are two wires coming from the Transmission switch, one is yellow and the other is Green with a Black stripe. To my surprise the Green wire was in active when the car was in reverse. This is the same color of the wire that feeds the tail lights. I was sad. Here is the question, has anyone ever replaced the reverse switch on the tranmission before? and if so, How hard is this fix?
Your help would be great if you have any info what so ever, Thank you very much
DJ
Old 05-06-2003, 03:14 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
I changed mine about a week ago, all u do is disconnect the two wires from the switch and then get a 17 or 19mm spanner (cant remember exactly then it just unthreads,
thread in the new one plug in the wires and yours done
Simple as that
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 05-06-2003, 07:35 PM
Thank you
hey thank you so much the help is gratly appreciated
Old 05-06-2003, 09:59 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
before you replace it, check to make sure it's not coroted ends, that all mine turned out to be, drove 1.5 years with no reverse only to find it was a 1 min fix.
check it dude.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 05-07-2003, 07:59 PM
Where would the corostion be? If this is the problem then that would be excellent. I have of water in my one of my tails but I don't even get power back there so I am pretty sure that it is not coroded ends but if you could explain what you mean then I will deffinatly check it out.
Old 05-07-2003, 09:57 PM
Kunundrum's Avatar
my corossion was the connection on the transmission (2 wires that connect in two other wire) the inside of that connection was full of corosion and no connection was being made.
how to adjust reverse light switch on 99 ML430 milltek ML-Class | GL-Class 0 06-02-2005 11:24 AM
Can anyone tell me where the Reverse light switch is Shootist Cherokee 3 04-23-2005 08:32 PM
Where is the reverse-lights switch? 93JimmyOwner Jimmy 0 03-18-2004 03:13 PM
no backup lights - reverse light switch? blhfla Golf 2 02-08-2004 01:51 PM
