Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 10-10-2009, 06:11 PM
nsman06 nsman06 is offline
94 Oldsmobile 98 Regencey Elite Issues HELP ME!
Hi own a 94 Oldsmobile 98 Regencey Elite with a 3.8L V6 engine. It has around 108,000 miles. And now for the problem part. Whenever i move the car back and forth for a while (ie parralle parking) the engine starts to rev up on it own and does not go down. It continues to do that until i turn it off. After i turn it off and turn it back on its fine. Another issue ive had is the Check Engine Light randomly coming on. But heres the strange thing if i turn the car off and then restart it the light stays off and doesnt come on again.... So if you think you could help me out that would be great!
Thanks
Old 10-11-2009, 03:09 PM
maxwedge maxwedge is offline
A990 racer
Re: 94 Oldsmobile 98 Regencey Elite Issues HELP ME!
Welcome to AF, try to get the code for cel and post back, there are several things that can cause this.
Old 10-26-2009, 01:41 PM
Is that the thing that plugs in to my cars computer system? (sorry im very new with more advanced stuff with cars)
Old 10-26-2009, 06:46 PM
A990 racer
Yes you need a scanner. 94/95 can be a transition year and a scanner may be required.
Old 10-26-2009, 11:45 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Chances are, your car is OBD1, so codes can be extracted without a scanner, using the method shown here.
http://www.youtube.com/watch?v=_3CzHCfz-9A
Note the diagnostoc connector on your car. If it has 12 pins, it's OBD1, and you can use the YouTube directions. If the connector has 16 pins, then you have OBD II and you need a scan tool.
Follow the directions. Once you have the codes, you can search on-line for an interpretation of the codes that you get.
Try this site:
http://www.extreme-check-engine-ligh...%20Decoder.htm
As for the idle problem, I wonder if there is a problem with your throttle valve. Intake manifold vacuum places considerable force on the plate, If the pivot point is sticky, worn or if there is carbon build-up, the vacuum force may be wedging it slightly open.
These can be cleaned up. Often, mechanics will remove the throttle body and clean-up the throttle valve and the idle air controller with carb cleaner and a toothbrush, for better idle performance.
Old 11-03-2009, 08:08 AM
Try this site:
where is the OBD1 on an olds 98? i went looking for it but its nowhere to be found. Do i need to pull apart the panel underneath the stearing column?
Old 11-03-2009, 02:53 PM
A990 racer
The port should be just to the lt or rt of the steering column just under the dash.
Old 11-05-2009, 07:05 AM
Okay i took my car to advanced yesterday with the check engine light on and get this my cars port is supposidly a hybrid of the OBD1 and the OBD2 sensor.... So he told me that i cant jump the engine light and i cant use an OBD2 decoder....So what would be the next step?
Old 11-05-2009, 07:34 AM
A990 racer
Any regular shop will have a high line scanner that can access the codes, or buy one for about 200-250, Actron is one( basic unit).
Old 11-05-2009, 08:23 PM
dang 250$?? crap then ill just take the old car to my mechanic and let him tell me whats up
Tags
check , engine , issues , light , oldsmobile
