Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-02-2003, 05:12 PM
slate slate is offline
Send a message via AIM to slate
Angry Is my BOV leeking?
I just installed a RevHard kit on my Si. The Delta gate has a 7psi spring and the adjustable screw is all the way in. I'm only getting about 5.5psi out of this thing. I know my cat is a little clogged. But my question is about the Vortech BOV that came with the kit. Is this thing supposed to be pulling air in the port when the car is ideling? If its pulling air in, is it letting air out under boost? Where's my other 2psi of boost!?
NO! I DIDN'T BUY THIS CAR AFTER SEEING THAT DAMN MOVIE!
Old 05-03-2003, 05:54 PM
Kill4A911's Avatar
Kill4A911 Kill4A911 is offline
Send a message via AIM to Kill4A911
could be, do you have an intercooler? that could lower pressure maby 1psi... id check the connectors for the piping, drip a little water on them and if it bubbles then you know
Civic:selling the D16Z6 getting ready for a B16 turbo
240Z:was thinking about a VG30DETT but am now looking at a V8
Old 05-03-2003, 06:05 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
its definatley not supposed to be pulling in air at idle. If it does then it needs to be adjusted. Make the tension harder asuming you have an adjustable one.
Old 05-03-2003, 06:42 PM
I do have the intercooler. I switched my vacum line from the compressor side of the turbo, over to the vacum line between the intake manifold and the stock fuel regulator. This way the deltagate read boost at the manifold after it went through the intercooler and all the piping. That produced a gain from about 4.5psi to 5.5psi. I really don't think its leeking at any of the pipe conections but I'll try the soapy water thing. (why didn't i think of that) So if it is the BOV, which does have the adjuster nut, what do I need to do with it? Send it off to have it looked at, or is there something I can do to it?
Old 05-03-2003, 06:45 PM
Sorry maxspeed. I just reread your post. Please disregaurd the last dumbass thing I said.........Thanks guys
Old 05-03-2003, 07:25 PM
Kill4A911's Avatar
let us know how it works, hopefully ill be in the market for a turbo kit soon.
PO 442A Evap Cntr small leek dedected wojtek90 Dakota 8 05-02-2005 07:20 PM
gas tank leek 92 cavyshack Rodeo | Passport | MU 5 02-28-2005 06:45 PM
86 Toyota, oil is leeking next to the clutch ToyotaDrifter Pick-Up 5 06-11-2004 02:11 PM
Fan not working and leeking colant azn3000GTRacer 3000GT/Stealth 8 05-06-2004 06:21 PM
Oil coolant housing Leek Dprado 4Runner/GX470 1 02-11-2004 03:05 AM
