Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 04-27-2005, 11:56 AM
wojtek90 wojtek90 is offline
Angry PO 442A Evap Cntr small leek dedected
I have Dakota 2001 V6 4.7l 9300 km.
My "check the engine" light is on by two codes Po 442A EVAP small leek detected and PO455 EVAP cntr Gross leek detected. I can delete them but after day or two light come on again. My question is what my coast this problem and how to fix it.
I have oil leaking from crankshaft seal. Can anybody give me instructions how to replace the crankshaft gasket. I never done it before and I don’t know how difficult it is.
Thank you for advice.
Old 04-28-2005, 03:57 PM
wehswarriorS-10 wehswarriorS-10 is offline
Send a message via ICQ to wehswarriorS-10
Re: PO 442A Evap Cntr small leek dedected
my truck has the same problem with the evap. system, i have a 2002 with a 4.7 and i dunno what to do about it
Old 04-28-2005, 05:21 PM
Dakota00's Avatar
Dakota00 Dakota00 is offline
Send a message via MSN to Dakota00
Most of the time a 442 code is the gas cap that isn't tighten. Check that for starters!!
Old 04-29-2005, 11:10 AM
Thank you for answering to my question. I will check or maybe buy new cap to start with, any other suggestions?
Tanks again.
Wojtek
Old 04-29-2005, 11:12 AM
Re: Re: PO 442A Evap Cntr small leek dedected
Please let me know if you find something about it.
Thank you.
Wojtek
Old 05-01-2005, 04:22 PM
pagerman38 pagerman38 is offline
Those codes that you have found are gas cap leak codes. Check your gas cap make sure it has click three times or the rubber seals or cap has not crack. I replaced mine with the same codes found codes by turning on you key but not starting the engine. Turn key 10 times on for sure codes. You can get rid of the check engine light by taken the postive cable off from the battery for 10 seconds.
Old 05-01-2005, 07:40 PM
Hi Pagerman38
Thank you for advice. It works.
I have to be more carefull when I turn my gas cap. So the lights won't come back.
Do you know how to replace the crankshaft seal, or mayby you know where to find info.
Thanks again.
Wojtek90
Old 05-01-2005, 08:55 PM
Dakota00's Avatar
I knew that was the problem, had it happen to me a couple of years ago. To check for codes all you need to do is turn the key on-off 3 times and it will display the codes.
Old 05-02-2005, 07:20 PM
Re: Re: Re: PO 442A Evap Cntr small leek dedected
Hi Pagerman38
Thanks again.
Wojtek90
No I don't know how to fix the crankshaft Sorry
