Old 05-02-2003, 03:41 PM
jjmjr48 jjmjr48 is offline
Programming Keyless Entry Remote for a 1994 Town & Country
I recently purchased a 1994 T&C which had only 1 Remote Keyless Entry fob. I purchased another RKE fob on Ebay and need to program the fob for use with my van. Can anyone help me get instructions to do this myself or do I have to go to my local dealer ? Any help would be greatly appreciated. Thanks JJM
Old 08-22-2003, 01:30 PM
dward dward is offline
programming for remote keyless
HI MY E-MAIL IS [email protected]
I LEFT INSTRUCTIONS FOR PROGRAMMING A 94-95 CHRYSLER CONCORDE AT THAT SITE. THE INSTRUCTIONS FOR A T/C SHOULD BE THE SAME.
ENJOY
DOUG
Old 08-22-2003, 05:51 PM
Hi Again
When You Find The Traction Control Connector--disconnect It.
Then Turn The Ignition Switch On.
Use A Paper Clip-make Sure The Metal Ends Are Exposed-jumper Between Pins 4 And 1. They'll Be The Two Pins Across From Each Other. 4 Is The Program Wire And 1 Is A Ground. Hold The Paper Clip In Position. The Locks Will Recycle. That Means The Old Program Has Been Cleared From Memory. Hit Any Key On The First Remote--the Locks Will Cycle-this Confirms The Program Has Been Reset. Do The Same Thing For The Other Remote. Reconnect The Traction Connector And Test Both Remote To See If They Will Open And Close The Locks. If Not You Will Have To Repeat The Process.
I Had To Do Mine Twice Before Both Worked. Both Remotes Have To Be Set At The Same Time.
Enjoy
Doug
Old 09-04-2003, 09:25 AM
nevets58 nevets58 is offline
Doug,
Will this procedure work on a 1996 Town and Country Lxi? I don't believe my van is equipped with traction control. Anyway, your help in this matter is appreciated!!
Steve
Old 09-04-2003, 08:28 PM
Re: Programming Keyless Entry Remote for a 1994 Town & Country
Originally Posted by nevets58
Doug,
Steve
HI NEVETS58,
THE PROCEDURE SHOULD WORK FOR ANY REMOTE PROGRAMING.
YOU NEED TO LOCATE THE REMOTE KEYLESS PROGRAM WIRE FOR YOUR VEHICLE. THE VEHICLE WIRING DIAGRAM WILL TELL YOU THE COLOR OF THE WIRE-MINE WAS GREEN. THE GROUND SHOULD BE BLACK. A MECHANIC SHOULD TELL YOU WHERE THE PROGRAM CONNECTOR IS LOCATED. IT IS LOCATED IN DIFFERENT PLACES. I KNOW WHERE MINE IS LOCATED. IF YOU DON'T HAVE TRACTION CONTROL, THEN YOU'LL HAVE TO FIND THE PROGRAM PLUG. SOME ARE LOCATED BEHIND THE GLOVE BOX AND OTHERS ARE LOCATED IN THE TRUNK. WHEN YOU FIND THE PLUG THERE WON'T BE ANYTHING CONNECTED TO IT BECAUSE THE DEALERS USE THE PLUG TO REPROGRAM A REMOTE FOR THAT VEHICLE.
THE DEALERS USE A LITTLE BLACK BOX. YOU DON'T NEED IT. WHEN YOU SHORT THE PROGRAM WIRE TO GROUND, YOU CAN REPROGRAM THE REMOTE(S)--ALL REMOTES HAVE TO BE REPROGRAMED WITH THE PROGRAM WIRE SHORTED TO GROUND. I WAS TOLD THAT THE OWNER'S MANUAL WILL TELL YOU WHERE THE PROGRAM WIRE CONNECTOR IS LOCATED. DON'T COUNT ON THE DEALER TO HELP YOU- THEY CHARGE $19.95 TO RESET YOUR REMOTE.
GOOD LUCK
[email protected]
PS I HAVE THE PICTURES AND INSTRUCTIONS FOR MY CAR.
Old 09-04-2003, 08:39 PM
Re: Re: Programming Keyless Entry Remote for a 1994 Town & Country
Originally Posted by dward
HI NEVETS58,
GOOD LUCK
[email protected]
HI STEVE,
I USED ANDREY VAKALICH. HE HAS SOME REMOTE PROGRAMING INSTRUCTIONS. HE CHARGES $6.95 IF HE HAS YOURS. HIS E-MAIL IS:[email protected]
GOOD LUCK,
DOUG
Old 09-09-2003, 02:22 PM
Thanks, Doug, for your reply and the information. I'll try this and let you know how it turns out. Thanks again!
Help in programming keyless entry remote for Gloria Professional Cedric | M45 | J30 | Gloria 2 09-14-2009 07:47 AM
programming keyless entry remote for a 2001 intrepid jefmon68 Intrepid 5 07-14-2005 11:08 PM
Programming keyless entry remote for a 2002 Intrepid SE theFREAKnasty82 Intrepid 0 07-13-2004 08:52 PM
anyone know how to program keyless entry remote for 96 camry? mylilshellbell Camry/Camry Hybrid/Vista 2 03-06-2004 03:36 PM
