Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-15-2003, 09:06 PM
mylilshellbell mylilshellbell is offline
Unhappy anyone know how to program keyless entry remote for 96 camry?
Does anyone know how to program a keyless entry remote for a 1996 Camry? Or does anyone know where I can read instructions to do this??? Thanks
Old 03-06-2004, 02:55 PM
qblop qblop is offline
96 camry remote programming
If anyone can answer this I've been searching the net for this info for quite some time and cannot seem to find anything. Thanks
Old 03-06-2004, 03:36 PM
Erndog1369 Erndog1369 is offline
If it is a Toyota system, there should be a control unit under the drivers seat. It's a black box with a few electrical connectors plugged into it. This might be a 2 person job, but if it's a Toyota, this will work.
There is a small green button on the control unit, it's kind of recessed, and you'll need to get a small screwdriver to get to it. All the doors must be closed, so the best bet is to push the drivers seat all the way forward, and access the control unit from the back seat. I suggest leaving the rear door open and kind of lay on the ground/back floor of the car, and have someone else hold the door switch closed, as if the door were actually closed.
Key on, door switches all closed, press that green button, and wait about 5 seconds..... press the button on the remote. You'll hear a beep, and you are done.
Any problems, e-mail me at [email protected]
