Old 04-29-2010, 06:45 PM
crazyoldergirlie crazyoldergirlie is offline
Hi, IN REFERENCE TO OTHER POST
Does the Grand Prix have 2 ELBOWS? on it ?????
THANKS
Old 04-29-2010, 06:50 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: Hi, IN REFERENCE TO OTHER POST
your '97 GP would have 2 coolant elbows. upper, and lower
Old 04-29-2010, 06:59 PM
Can you tell me where the second elbow is located? and do I have to take the tensioner off again?
THANKS...
Old 04-29-2010, 07:01 PM
Re: Hi, IN REFERENCE TO OTHER POST OOPS!
I meant tensioner belt...
Old 04-29-2010, 08:16 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
THANKS...
The coolant elbows are located at the upper right and lower left corners of the radiator, I guess the one you already saw is the one from the upper right. The other elbow is accross the diagonal line of the radiator, near the serpentine belt and next to the air conditioning compressor.
Hope this helps you, good luck...
Old 04-29-2010, 11:23 PM
I'm talking about the heater bypass elbows.... Is that the ones you mean also? If it is one elbow goes to the tensioner and in the back of the tensioner it has a nipple that goes into the water pump is this the second elbow? Sorry If I'm not getting what your saying... THANKS! What I really could use is a diagram, if there is one of the water passages in the car???
Old 04-29-2010, 11:30 PM
olopezm's Avatar
Oh my ! I'm terribly sorry for my mistake, that's what happens whenever you have no idea what people is talking about. Now i know which ones you are talking about, if you want to bypass the heater core you just have to connect a hose between both nipples on the tensioner belt. Here is a link to an image showing the belt tensioner, just connect a hose between both terminals:
Old 04-29-2010, 11:43 PM
Is there any way you can send a picture of a 3800 1997 Grand Prix engine with a diagram of it??? PLEASE! if possible...Thanks so much for your time also
Old 04-29-2010, 11:58 PM
olopezm's Avatar
You are welcome, I have the same bypass on my '97 GP I will take a picture of it and upload it for you in the morning. Take care...
Old 04-30-2010, 07:52 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Are you attempting to bypass your heater core, or just replacing the leak-prone plastic elbows? If you are referring to the plastic elbow(s) that come(s) out of the lower intake manifold to the belt tensioner, your car only has one. The 99-later 3800's have two, one upper and one lower. The lower fitting on 96-98's is a cast in part of the tensioner assembly, so the lower plastic elbow is not required on these years. Motormite/Help sells them as a pair (part #47065), so you'll only use the upper on your vehicle. If you're talking about the heater hose fittings at the top of the tensioner, then you do have 2, but they are not available aftermarket that I know of.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-30-2010, 09:32 AM
olopezm's Avatar
Here you go, I hope these pictures help you fix your problem:
Old 04-30-2010, 10:56 AM
i messed up, I'm sorry. 97 and 98 have 1 coolant elbow. as rich said, in 99 they were "revised" and changed to 2. upper and lower.
its been a while since I've done one. again...sorry for the misinformation
Old 04-30-2010, 11:10 AM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Idiot.
just messin
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 04-30-2010, 11:36 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Actually there technically are two elbows on the 97, its just only one is plastic and replacable. The other one is metal and one with the tensioner assembly. It does have an o-ring that should be replaced if you take the tensioner assembly off.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-01-2010, 06:58 AM
BNaylor's Avatar
BNaylor BNaylor is offline
crazyoldergirlie,
To cut down on confusion or replies out in left field or dead wrong how about posting a link to the "OTHER POST". Your future cooperation is appreciated.
Gentlemen,
See link below.
Click here
Timeslip 08/12/06
AF Community Guidelines
