Old 05-01-2003, 03:37 PM
appleseed's Avatar
appleseed appleseed is offline
two tone paint scheme help
i'm working on a two-tone paint scheme here (solid base color and the second color to be a metallic) and would like some suggestions as to how i would go about minimizing the paint build-up around the masking area and on how to eliminate the 'step' at the point where the paint interfaces each other. i believe hawk sanded down the racing stripes that he painted on his mustang. not too sure i would feel comfortable doing that. any thoughts or techniques you guys would like to share on this? since one of the colors is metallic, is sanding safe? or should i just clearcoat it and sand/polish as normal? i would greatly appreciate it if anyone who has expereince with this would share their experience(s). thanks!
a.
Old 05-01-2003, 03:41 PM
daggerlee's Avatar
What I do is spray the two colors, then put a thick layer of clear over the two colors. Make sure neither color is affected the primer base, or you may end up spraying one color first and the second later (i.e. if you're painting white/black, then spray white first then black). Then clear the whole thing, the clear will "gloss" over the paint "step"
To get a good mask, brush Future Floor Finish over the masking tape after you apply it, this little clearcoat makes sure no paint can get under the tape.
Dan
Old 05-01-2003, 04:01 PM
Jay! Jay! is offline
Horizontally Opposed
On my WRX, I sanded with 2400 grit along the direction of the transition line as well as across the line from the top layer to the bottom layer. Light sanding will knock out 95% of the buildup of paint that collects along your mask. Then a couple clear coats will bury the seam enough to polish without worry.
(my 2¢. )
Hierarchy of Subaru:
(Click to see mine!)
Old 05-01-2003, 05:57 PM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
sanding a metallic paint will remove the metallic chips from the color and give you rough look. I don't advise it. I'd spray one or two coats of clear, then sand around the area where the "step" is to smooth it out. I'd also besure to go up to 2000 or higher grit. Afterwards, wash the body well, then spray another coat or so of clear, then polish and wax. I repeat myself when I say I don't advise sanding a metallic paint.
Old 05-01-2003, 06:47 PM
appleseed's Avatar
thanks for the response guys. i might just spray the metallic color on just enough for coverage and clearcoat the whole thing. i'm just worried about the metallic chips. i'll let you know how it turns out. thanks!
a.
Old 03-03-2004, 09:14 PM
weswes1 weswes1 is offline
Re: two tone paint scheme help
Appleseed, use a clear base over both colors before clear coating (exBC 500) you may sand with out damaging metalics, and retain a smooth over lap between colors.
Old 03-04-2004, 02:11 AM
chariot_gdi chariot_gdi is offline
Hi, I'm also working on a kit tt requires two tone paint scheme,metallic and non-metallic, which paint should i spray 1st?
Two tone paint cfcrules Car Modeling 3 04-05-2006 05:27 AM
Two tone paint job razgriz Car Modeling 5 01-06-2006 02:48 AM
two-tone paint job dopenoze Integra 5 06-10-2005 07:48 AM
Two Tone Painting help Honoturtle Car Modeling 8 06-27-2004 10:59 PM
Hot off the workbench...350Z Track Edition w/two-tone paint scheme ZoomZoomMX-5 WIP - Street 25 03-05-2004 01:20 PM
