Old 04-27-2003, 09:17 PM
michaelsd16c michaelsd16c is offline
more problems
Ok where should I start. I am in traffic or a stop light and my car temp starts to go up. I got an auto meter(water)temp that shows me that the temp is starting to move up like to 210. Thats when I roll down the windows and put the heater on full blast so that it dosn't go any higher.
I got R&C racing radatior and I got a 160temp thermostat and I change the fan switch for a new one from the dealer and I also got a coolant sensor form the same place. So what is their left? But when I am driving on the freeway or on the street the temp stays at 160 to 178.
Please don't say it's a blown head because its not, if it was... my car would be driving like $#%@ Whats that vaccum press you say?... it says 21 and that is perfect because the dealer told me that the vac press should be between 17 and 21. Please don't make me go to the dealer PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! They said the can fix it for an arm and a 10inch d!ck
Me no have! Help!!!!!!!!!!!!!!!!!!
Old 04-27-2003, 10:07 PM
Kill4A911's Avatar
Kill4A911 Kill4A911 is offline
Send a message via AIM to Kill4A911
are you sure the fan is switching on?
Civic:selling the D16Z6 getting ready for a B16 turbo
240Z:was thinking about a VG30DETT but am now looking at a V8
Old 04-27-2003, 10:12 PM
yes it turn on around 210or 215 and at that temp my car start to overheat
Old 04-27-2003, 10:24 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
......check your radiator cap......we just learned today on my dads civic it was broken and came apart very easily his car still overheats but i think its the waterpump
2002 Acura TL Type S
1991 Honda Crx Si
Old 04-27-2003, 10:57 PM
nope the radiator cap is fine and i think if the water pump was bad it would be overheating all the time and I would be have serious problems
Old 04-28-2003, 01:37 AM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
when was the last time you change your coolant and who did it?
try changing your coolant (50% water 50% coolant) and make sure whoever do it to bleed the system right. Also check the coolant level.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 04-28-2003, 08:37 PM
I drained it my self. As for the coolant I got it from the dealership which is 50/50 and I aslo bleeded it until it bubbled no more.
Old 04-29-2003, 01:21 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
it seems like you got pressure lost somewhere, did u check all your hoses and make sure it on tight and no leak anywhere. if all yoru hoses are good then i would also agree that the water pump is bad. my car had a bad water pump once, in traffic it would over heat, but once i got hte car going, it was ok
Team Lonely Drivers
Old 04-29-2003, 10:38 PM
I checked all the hose's and their is no leak. Their is one thing. I noticed that the reserve tank is just about full(of coolant)meaning that it is above the normal limt. When I check the radiator it has lost some coolant but when i pour the reserve tank that is almost full into the radiator it feels up with the overflowing amount. It leaves just enough in the reserve tank that it levels out to the normal amount that it should have. For Examlpe the radiator loses about a cup of coolant and that coolant get stuck into the reserve tank and dosen't get back into the radiator. So I think u must be right about the pressure lost. Some one told me that the water pump works or it dosen't work at all. Is this true? And is it hard to fix? Whats
(hte)?
Old 04-29-2003, 11:30 PM
u better watch out because i lost a motor because the water pump went bad, the bearing went and eventually it started leaking and it soaked my timing belt, which then caused my belt to snap bending 8 valves. yeah it will stiill work but its usually the bearing going so it kinda starts to wobble, which then the water pump isnt flowing 100%. that why it works when u driving highway but not in city. like highway driving u got the cold air flowing in the engine through the radiator, but city u dont got that. if your cooling is good it should do that.
well u say u replaced everything in yoru cooling system but the water pump, and u say theres no leaks anywhere. umm another possibility is that its your heater because if that has a hole in it, that could be your leak right there. if u havent replace your timing belt or your water pump in like the 60,000, it would be a good time for a t belt and water pump change
here a list to make it easier incase u dont understand my rambling
water pump and or heater.
Team Lonely Drivers
Old 05-01-2003, 07:17 PM
Well I check the heater for leaks and nothing. But I forgot to say that when I was in traffic my car would starting to overheat. I would turn the heater on and for some reason it would stop putting heat and it would go to cold. I would have to pull over and let the car cool for a while. Sometime the traffic wouldn't be that bad and as soon as the car would start to move agian the hot air would come back. As for the water pump I don't think it leaks because I have been having this problem for 8 months and I drive it pretty hard sometimes.
Old 05-05-2003, 01:29 AM
SiRII's Avatar
SiRII SiRII is offline
replace the thermostat. i've encountered that same problem twice already. and both times were the thermostat.
Old 05-05-2003, 08:39 PM
It can't be the thermostat because I have already change it 3 times. The main problem is that the fan wont come on at the right time.It dosen't come on when I am in traffic. I know this because the dealer (honda) had told me. That it is the FAn. But he wouldn't tell me why because$$$.
Old 05-06-2003, 05:33 PM
candlaudio candlaudio is offline
Send a message via Yahoo to candlaudio
i may be wrong but more than likely you are gonna have to run a toggle switch to your fan and when you are in traffic like that cut the fan on manually and when you start moving turn it off other than that you will have to go back to the dealer unless im wrong and someone else helps you out
Old 05-06-2003, 05:43 PM
SiRII's Avatar
check your fuses. isn't everything on the honda electrical?
ugh...more problems...more headaches DeadBlade89 Cavalier Problem Diagnosis 1 11-22-2007 11:25 PM
Problems, problems, and more problems... Noelles2000TL CL | Inspire | Saber | TL 4 08-05-2004 10:58 PM
problems problems and more problems tacoma man Monte Carlo 1 05-12-2004 09:57 PM
Problems, Problems and more.... Problems. Killa_CRX '88 - '91 Civic | CRX | Wagon | Shuttlee 6 03-02-2004 03:01 PM
Problems, Problems and More PROBLEMS!!!! 1PhatCX '88 - '91 Civic | CRX | Wagon | Shuttlee 15 06-21-2003 11:59 AM
