Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 02-21-2003, 10:30 PM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
Well, I advise you get a FWD daily driver that will be good on gas, and work on a RWD project car for fun
You could get a RX7 and put a V8 in...
Then again, a swap you would probably appreciate more would be the Audi AYB or AAN 5 cylinder swap into a Porsche 924. Mild tuning, 350 hp... 2200lb car with a little lightening. Suspension parts, brakes, it's all available
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 02-21-2003, 10:46 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Originally posted by Octagon
There's only one factory transaxle I know of that can fully take 300hp, and that's in the Northstar Cadillacs and I think a few other GM products, too.
You are forgetting the A-555 and the A-568.
Old 02-22-2003, 06:14 AM
RACER D12's Avatar
RACER D12 RACER D12 is offline
Send a message via AIM to RACER D12
I would but I cant afford two cars right now so I will just have to find the right Rwd car for me
Lindsey Boost Enhancer, Blitz EBC, Hot Air Intake, Koni Yellows
Old 02-22-2003, 12:37 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
um, yeah...
a vr6 jetta can more than take 300hp the transaxle won't have issues...
if you're street racing, you'll want low end, b/c once you're off the line, if you're in the lead, you should be able to stay there..
i know that there are cars with good low end, but they're not designed to be drag raced... and may not have gearing for the high end, or not the right gearing for quick acceleration...
it all depends on the car...
you could easily get a vr6 jetta and a www.eiptuning.com turbo kit... then you're flying...
or get an older jetta, mk2 and swap a 1.8t or vr6 into it...
www.overboost.com has an article on a mk2 gti that has a 1.8t in it with a mk3 jetta gt trans in it...
there are tons of easy crossovers and bolt ins, and any vw trans will bolt to any vw motor...
not nearly as complicated as hondas...
Old 02-22-2003, 01:05 PM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Originally posted by flylwsi
um, yeah...
So sure? My brother-in-law started having major transaxle problems on his turbo Jetta at 240whp
There's no replacement for displacement...No, not even a turbo.
Old 02-22-2003, 03:39 PM
vr6, not 1.8t... i'm not sure if they run the same trans, but i think they're different...
and if he's got 240hp, that's prolly at the wheels, which puts you much closer to 300 at the fly...
i've seen quite a few articles on big power'd vw's with stock tranny's so...
Old 02-22-2003, 03:57 PM
Cbass's Avatar
VW is like the German version of Toyota, usually torquey engines, and everything is overengineered and much stronger than it has to be.
I know of one little company that does Quattro/4Motion swaps into A platform cars, such as the Jetta/Golf/Beetle. They had a showcar a while back, using the drivetrain of an S4, with the suspension and brakes from a 996 TT. Only visual cues that gave it away were a small wing on the back, and 996 TurboTechnology wheels. It made about 500hp at the flywheel, btw.
My advice is get a Jetta MK2, they are great cars, make awesome daily drivers. If you want to go crazy on it, you can convert it to AWD. For $500 you can pick up a 924 in need of a little work, and turn it into a frightening fast car.
Old 02-22-2003, 04:27 PM
RACER D12's Avatar
Funny you should say that there is a 924 two towns over dont think it runs and it just sits their I think the guy would sell it(if you saw his house/apartment you can tell he needs cash) but I dont know if I want to do all that work. I mean I dont have a license yet so i guess I would have time to work on it but it might be two much for me. I should see if it runs or not but I dont think so it just sits there in his driveway with a flat rusting.
Old 02-22-2003, 04:44 PM
Cbass's Avatar
Well, look into it!
There are usually two reasons a 924 is off the road, one would be problems with the fuel system, which can gum up if left sitting for a long time, or the synchro rings in the transmission are worn out.
Go have a look at it, they are very good cars, and very reliable. They have an Audi engine, and VW brakes, but Porsche suspension. This means all the parts that will wear out are cheap to replace, but all the parts that make it a blast to drive are Porsche
Old 02-22-2003, 06:08 PM
keep in mind that although the porsche is cheap, the replacement parts sure aren't...
mk2 vw all the way...
Old 02-22-2003, 09:04 PM
Fliquer Fliquer is offline
Send a message via AIM to Fliquer
fwd cars, especially on the street, have the same traction as a rwd car... the power transfer is a different story, but you won't have any major issues...
Weight transfer is a very significant part of launching. When you accelerate, weight is transferred to the rear of the vehicle (off the front wheels and onto the rears). This is why RWD cars are inherently better than fwd cars when it comes to launching (all other factors being equal).
Those who said add a LSD, wider rubber, and upgrade the suspension, I agree with them.
Isitcontagious.com
'92 S13 coupe
KYB adjustable struts + Whiteline springs
Urethane bushings in all control arms and subframe
Cone Filter
Next up: LSD
RIP #05
Old 02-23-2003, 05:39 PM
RACER D12's Avatar
WHAT DO YOU MEAN BY POWER TRANSFER!!!
Old 02-23-2003, 07:05 PM
Cbass's Avatar
Did you read my post? The parts that wear out are Audi/VW, making it cheap to run.
Power transfer would refer to one of two things, transferring power from front to back, as in a AWD car, or left to right. A LSD will optimize the power from left to right.
FWD is great for a daily driver, but not for a performance car. You can make a FWD car fast, true, but it takes more money than a RWD car, and it will have inherent problems you cannot work around.
Get the 924, you know you want to
How can you go to Allans shop to get a pin turned on & not get a tune??? Moze Silverado 10 03-30-2006 10:19 AM
How can i get WRC stuff in USA? shrubchild Rally 5 08-28-2002 01:28 PM
HELP how can i get these to fit!!! TomB Tires and Wheels 0 03-31-2002 08:48 PM
