Old 02-12-2003, 06:19 PM
xxpolo47xx xxpolo47xx is offline
Send a message via AIM to xxpolo47xx
hmm, i had a similar problem and the main relay was the problem. How did you check your main relay switch?
Old 02-13-2003, 07:03 AM
90civichatch 90civichatch is offline
Send a message via AIM to 90civichatch
I checked the main relay yesterday, it works fine. Car still wont start.
1990 Honda Civic Shit-box, Sold.
Old 02-13-2003, 11:42 AM
turbcivic's Avatar
turbcivic turbcivic is offline
Originally posted by jeef
it takes air too...
but you should check your timing too... the belt could have jumped a few teeth causing you grief...
the compression is the air. As the piston moves up, it compress the air, which is kinda hard to block and gas for combustion.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 02-13-2003, 01:18 PM
I checked the compression, its about 160 on all cylenders. So it has spark, compression, fuel pump works and main relay is fine. The timing belt looks good, doesnt seem to have jumped any teeth. I dont know what else to check.
anything?
Old 02-13-2003, 01:40 PM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
There is gas in the tank right?
Old 02-13-2003, 02:23 PM
Yes, I have gas. I filled it up the night before it broke down. I had half tank when it died.
Old 02-13-2003, 02:39 PM
Civic Rush's Avatar
Now i am not just asking questions to make anybody feel stupid, but is that what the gauge says or is that what the tank sounds like?
Old 02-13-2003, 03:37 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
anything?
Did you do a wet compression test or a Dry compression test ?
Turbo Civic is right. it takes Fuel, Spark, and Compression for a engine to run.
The night before it broke down did it idel high, anywhere between 1200-2000rpm ? if so you could of had a vacume leak, or blew off a vacume line.
You should try and find someone with a Scanner. (thing that hooks to your ECU and gives you full readouts on all elecrical / mechanical system in the car.)
That will point out exactly where the problem is
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 02-13-2003, 04:05 PM
turbcivic's Avatar
You can't hookup a scan tool to cars with theire original ecu. Only odb II ecus
Old 02-13-2003, 05:41 PM
I did a dry compression test.
My car was running perfectly before it broke down. I drove it 2 hours before and it was fine, nothing abnormal. The second time, it started fine, and even climbed out of the snow. I drove up the road, stoped at a stop sign, then went. 1st gear was fine then 2nd; before I shifted 3rd the motor died, and would not start again.
Since it is a DX I have no tach so I'm not sure of any changes in RPMs, but it sounded and ran fine, up unitl it broke down.
-Sorry for the long post-
Old 02-13-2003, 08:23 PM
Tanked Tanked is offline
My CRX has been having starting issues lately (it's being repaired right now), and the mechanic said it had a bad oxygen sensor. The car would start strong and catch and immediately die after the starter was disengaged. Might be work checking out.
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 02-14-2003, 08:24 AM
My car does'nt start at all. It turns over but never starts. Sometimes when I am trying to start it, it makes a "popping" sound coming from under the hood.
-What do you guys think?-
WONT START, need help fig. out what the hose is 4 mrs.k.m.ashby Grand AM 0 02-12-2011 05:07 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
91 civic wont start....PLEASE HELP!!! civic91zcdohc '88 - '91 Civic | CRX | Wagon | Shuttlee 1 03-23-2005 10:12 PM
1995 camaro wont start need help!!! llbigj04 Camaro Discussions 1 02-06-2004 11:00 PM
Car Wont Start, Need Help Asap!! branman_crx_guy '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-16-2002 08:53 PM
